Westy turbo
westy turbo
  • Replies 124
  • Created
  • Last Reply
Top Posters In This Topic
Used actualy 2 Γ alloy brackets(X2),and mound it on the spare tyre bracket mounts,reshape the grp lower wishbone area so clearence is ok when the car is lftted,fitting 2 strakes on it,looking at suporting with a billet pump/filter mount, crotch strap is in+new possition of the belt mounts for future hans use.
http://i121.photobucket.com/albums/o217/tigraturbo/P2150322_zps1a718b33.jpg
http://i121.photobucket.com/albums/o217/tigraturbo/P2150321_zpsd8e9cb7b.jpg
http://i121.photobucket.com/albums/o217/tigraturbo/P2150319_zps76f71d61.jpg
http://i121.photobucket.com/albums/o217/tigraturbo/P2140309_zps4f29cd73.jpg
  • 4 weeks later...
Fitted a 3071 shaft to my current housing just to test it on the dyno
that planning to go in order to check the duty cycle on the injectors,
might go higher on advance timing too as its only at 12 degrees are there now,
headphones/etc will tell..
Not trying to squeeze it out,thats why didnt go to an actual turbo replacement,
just to help it breath out better+the shorty ex can in addition with the
3.62 diff thats on now,as with the 3.92 couldnt get it unleashed.
Edited by westy turbo
  • 2 months later...
True about the tire stack....as far as the grip was on michelin slicks,
airline had huge amounts of dust that came up all the way from Africa,
so 0.45 bar felt ok as i was my first run after 3.5 months with both forearm/wrist bones brocken....
  • 1 year later...
Went to 87 lb injectors few months back as couldn't raise the boost more than 1.1 bar and had some really nice figures,no other changes except taking off the actual can and fit a straight kinda say pipe...
http://i121.photobucket.com/albums/o217/tigraturbo/10494265_10152522120436600_437144368_o_zps1b6455c1.jpg
Just to share few pics with the new color,painter was feeling like lets change it a "bit" so couldn't resist the offer...its an aprilia bike Perl flat color which didn't think that i will like that much+ finally got racing plates so outside change to celebrate it :hurray:
Thank u all guys! the Michelin a great tire and by the time they heat up,they are awesome! using 18psi cold,but on a slow track like the one on the pics, they don't have the time to heat up....either going on Hoosiers,or to Kumhos ecsta that i had them in the past and they perform fantastic!
