Sprockett
  1. Thanks for the reply Bruce, I have emailed you.
  2. Hi Terry, The narrowest point (outside the v-nose) would be between the fenders. They are standard width axles so this would be the same as most any enclosed trailer even a 30 footer. I've never actually measured this but 80" seems to be standard. I also believe the door opening is the same, 80" wide. The rest of the box would be about 86" wide inside. Please let me know if you have anymore questions Terry. Thanks, Ryan
  3. Why buy an open trailer and deal with weather and security issues? Trailer is Located in Calgary AB Canada. I am willing to deliver within reason and cost. Custom built by Rance in 2010, all aluminum trailer. - 14 foot box + 4 foot v-nose (exterior) - 7.5 feet wide (exterior) - Custom low roof 6.5 feet tall - ~21 foot total length - ~2000 lbs total weight Trailer fits under a normal 7' residential garage door. Stored always indoors in my 24x24 garage. Excellent shape and will always look new with all aluminum construction. This trailer was custom built to haul my small race cars behind an SUV with a 6500lbs tow rating. Total weight with an Seven loaded could still be towed with a typical 5000lbs tow rated SUV. Has a 5000lbs payload and could be used for any number of things while still fitting in many residential garages. Tow sleds, quads, motorcycles, work/landscape equipment, go-kart, small cars, etc. Standard features: - GOODYEAR TIRES - Rubber Torsion axle with EZ lube hubs - Electric Brakes on both Axles - (2) 12V dome lights - Rear ramp with spring assist - Bonded .030 metal with screwed seam - Flip-up tongue jack - All L.E.D. lights - L.E.D. fuse panel - Marine-Grade Plywood floor (7-Ply) - Aluminum cambars on ramp door with grease zerks - .024 Seamless aluminum roof - 4 D-Ring tie-downs - Roof vent - Stoneguard - Stainless steel hinges with grease zerks Options on this trailer include: - WARN M6000 - 6000lbs winch - Interstate Deep Cycle battery - charges with vehicle - 48" extended RV side access door - 'Escape' door over drivers fender - 8" ramp door bumpers to load low car (not shown in pics) - 225 15" tires - Full size spare tire and external mount Selling because I have bought a dedicated F350 tow vehicle and am upsizing my car. $8,000 as is. $7,000 without the winch and battery http://i164.photobucket.com/albums/u24/ryansclarkcar/Trailer/IMG_4314.jpg http://i164.photobucket.com/albums/u24/ryansclarkcar/Trailer/IMG_4315.jpg http://i164.photobucket.com/albums/u24/ryansclarkcar/Trailer/IMG_4317.jpg
