LarryMSI
Everything posted by LarryMSI
  1. Currently California smog exempt and currently registered Registered via California SB100 Dunnel ZX1 210 HP engine Weber 45mm DCOE Dunnel ignition control unit Dunnel lightweight steel flywheel Dunnel oil pan with windage tray MSI ZX1 alternator mount Water rail kit MSI expansion tank ITG air filter Transmission 5 speed ford T9 with quaife close ratio gears Quaife limited sip differential MSI rear radius rod kit Option Extras that fit this car specifically 15 gallon fuel tank requires removing the trunk liner Koni spring and shock package (TRACK ONLY) Rodger Hamlin roll cage $28,000 or best offer Please contact Larry or Cheryl 707-448-1282
