bear01011
  1. Reproduction of the traditional Brooklands Racing Screen. Screen includes a polished aluminum frame, safety glass and chrome plated brass mounting hardware. 224-100 2 available: 1) Brand new in box: $110, shipped to contiguous 48 United States 2) Previously installed, shows some patina, all parts included (pictured): $100, shipped to contiguous 48 United States Contact Kim Baker at kbaker at vintageracecarsales dot com
  2. Selling Caterham Duretec 480; stainless steel Two Stage Muffler, includes valve to open straight thru or quiet. $350 Or possibly will sell the Complete stainless system, Muffler, heat shield, Cat converter, header. $1800 only 2700 miles on it. See pictures here, https://vintageracecarsales.com/portfolio-view/2013-caterham-seven-480/nggallery/page/4 4 pages of photos , click on thumbnails to enlarge or buy the car for $48,900 237Hp 6 speed fully optioned Kim Baker 413 329 0214 http://www.usa7s.net/vb/attachment.php?attachmentid=15878&stc=1
  3. Original Lotus 7 Fender Bracket selling for $100 with free shipping to the continental United States, additional shipping costs will be applied to international shipments Please contact Kim Baker by calling 413-329-0214 for additional information http://www.usa7s.net/vb/attachment.php?attachmentid=14368&stc=1
  4. Miscellaneous Lotus 7 Fenders Used Located in Western Mass, $200 to take all of them, PICKUP ONLY Please contact Kim Baker by calling 413-329-0214 http://www.usa7s.net/vb/attachment.php?attachmentid=14366&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=14367&stc=1
  5. SOLD 1959 Lotus 7 Series 1 Vehicle is located in Pennsylvania Offered at $47,500 Lotus chassis number: 796 Progress frame number: L559 759 Probably the most exceptional Lotus 7 Series one in existence Chassis: Completely-new paneled chassis fabricated by Pat Prince, Prince Race Car Engineering in 1990. Upgraded steel transmission/tunnel support correcting original Lotus design weakness. SCCA spec bolt-in roll bar by Prince Race Car Engineering. All new front and rear aluminum wings (fenders) by The Panel Shop. Stainless steel real wing guards by The Panel Shop. Custom Fuel Safe fuel cell. Motor: BMC serial number: 9M-U-H 148239 All steel 948 by Leydon Restorations – Moldex crank, Carrillo rods, Elgin cam. Steel center main bearing cap. 12G295 head with oversize valves. Ported by Leydon Restorations. Duplex timing chain with adjustable cam gear. Twin 1 ¼” SU Carbs – modified for better air flow by BHP Developments. Custom air horns. K&N Filters. Custom 3 into 1 header and exhaust by BHP Developments. Ceramic coated. Includes provision to add SuperTrapp diffuser discs (included) for noise reduction, if needed. Mocal oil thermostat, Mocal oil cooler, braided stainless steel oil hoses. Canton billet remote oil filter. Oversized, baffled oil pan. Accusump oil accumulator with electric valve kit. Aldon distributor. Oversized radiator. Drive Train: Straight-cut, close ratio, synchro rib-case transmission. Rebuilt by Leydon Restorations. Tilton aluminum flywheel with replaceable steel friction surface. 5.375:1 differential. 4.875:1 spare differential included. Double bearing rear hubs. Original Metropolitan rear axle housing with custom fabricated coil-over mounts, putting mounting bolts in double shear. Suspension/Brakes/Wheels: Spax adjustable coil-over shocks. Adjustable spring perches. AN hardware utilized at all suspension attachment locations. Rebuilt rack and pinon assembly – zero play. Borgeson steering shaft u-joints. Removeable steering wheel. Dual-circuit brake master cylinder. Stainless steel braided brake and clutch hoses. Tilton brake proportioning valve. 15” x 4 ½” x 60 spoke spline-drive painted wire wheels with Dunlop Racing 5.00 L-15 tires (204 compound.) Electrics: All new chassis wiring. Upgraded circuit from 2 to 4 fuses. Lucas head lamps. Wingard tail lamps History: Imported into the USA in the early 1980s from the Isle of Man. Participated in VSCCA events. Current owner (mechanical engineer) purchased the car in November 1987. Complete 9 year nut and bolt restoration with documentation. VSCCA participant from April, 1997 through April, 2005. In storage since April, 2005. Titled/registered in PA as antique vehicle. Additional Notes: Production number 147 of approximately 243 Series 1 cars. Included in the sale are all of the original (well worn) parts removed from the car prior to the restoration, including the original chassis (to prove this car isn’t a clone.) Other original parts include: VIN plate Stock windscreen Hood (convertible top) and hood support sticks Tonneau cover Wiring harness Gauges Windscreen wiper motor mechanism Horn Emergency brake mechanism Radiator Fuel tank Muffler Rear wings Front and rear suspension components (coil overs, control arms, uprights, brake items, etc.) [*]When the new chassis was constructed, Pat Prince fabricated an additional bonnet (hood), and scuttle panel. These spare items are included and could be used to convert the car to full road trim, if so desired. [*]Curb weight 1035 pounds w/o fuel. [*]No off-track excursions. Never spun. [*]Car has always been kept in dry environment under cover. Never seen rain [*]Photos are current Additional photos can be seen by visiting our website: http://vintageracecarsales.com/portfolio-view/1959-lotus-7-series-1/ Please contact Kim Baker by calling 413-329-0214 for any additional questions http://www.usa7s.net/vb/attachment.php?attachmentid=14126&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=14128&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=14130&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=14133&stc=1
  6. Set of 8 Crane Valve Springs Crossflow / Pre Crossflow Ford Crossflow and Pre-Crossflow Brand New Part Number: 99859 Selling for $60 with free shipping to the continental United States, additional shipping costs may apply for international shipments If interested please contact Kim Baker by calling 413-329-0214 http://www.usa7s.net/vb/attachment.php?attachmentid=13438&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13439&stc=1
  7. Looks and feels like new 10 1/4 inch diameter from outside to outside 3/4 lbs Super lightweight Selling for $130 with free shipping to the continental United States, additional shipping costs may apply If interested please contact Kim Baker by calling 413-329-0214 http://www.usa7s.net/vb/attachment.php?attachmentid=13418&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13419&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13416&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13417&stc=1
  8. Selling for $90 with free shipping to the continental United States, additional shipping costs may apply elsewhere Lotus Seven Wedge Extension Adaptor to move gearshift handle back in Lotus Seven with Used Triumph Shift Extension Triumph Shift Extension Needs to be cleaned and lubricated If interested please contact Kim Baker by calling 413-329-0214 http://www.usa7s.net/vb/attachment.php?attachmentid=13358&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13359&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13361&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13362&stc=1
  9. Were fitted to a Lotus 7 Series 3 but were removed to install original wheels Wheels have no blemishes in the aluminum, have a few scuffs in the paint only 13" x 7" 4 1/4 bolt circle 4.5" back space Selling for $450 plus shipping Shipping fee may cost around $100 depending on location within the continental United States If interested please contact Kim Baker by calling 413 329 0214 or email kbaker at vintageracecarsales dot com http://www.usa7s.net/vb/attachment.php?attachmentid=13176&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13177&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=13178&stc=1
  10. Original Lotus 7 (not cater ham) with excellent glass Selling for $600 plus shipping. To view pictures of this part, please click here: http://vintageracecarsales.com/portfolio-view/lotus-7-series-2-and-lotus-7-series-3-windshield-original-with-excellent-glass/ For any questions or information please contact Kim Baker at 413-329-0214
  11. Should fit most 7 variants. Good condition Selling for $95 shipped Can be seen here: http://vintageracecarsales.com/portfolio-view/amco-windshield-wind-wings-from-lotus-7/ For more information please contact Kim Baker at 413-329-0214 or email kbaker @ vintageracecarsales . com
  12. We currently have a Cosworth YAC/YBM Jennings Motor available for purchase. This motor was disassembled during a scheduled refresh. The owner decided to replace the motor with a Duratec during the refreshing, so it remains unassembled. The engine includes all photographed parts (see our website, link below). Specifications: 12 bolt crankshaft TDC dry sump pump Cast aluminum oil pan Weber intake manifold Cosworth pistons Asking $4500, will need to be freight shipped. Contact: Kim Baker 413 329 0214 Photos: http://vintageracecarsales.com/portfolio-view/cosworth-yac-ybm-jennings-motor/
  13. Crane Valve Springs for sale. Brand new NIB. Part # 99859-8 Asking $50, shipped. Contact: Kim Baker 413 329 0214
  14. Rocker Arms + Shaft for sale. Appears to be new or as new. Asking $125, shipped. Contact: Kim Baker 413 329 0214
  15. Dry Sump Valve Cover for sale. Fits Ford 4 cylinders, crossflow and pre crossflow Condition is new. Asking $50 shipped. Contact: Kim Baker 413 329 0214 http://www.usa7s.net/vb/attachment.php?attachmentid=12122&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=12123&stc=1http://www.usa7s.net/vb/attachment.php?attachmentid=12124&stc=1
