I have a set of rear wings that came off a 1964 seven series 2. These are the wider 11 inch version.
$100 for both. Located outside of New Orleans, La. Not sure how much to ship.
Have confirmation through John Watson on history. The only change, I believe, is reinforcement of rear axle where it tends to flex.
Would you guys have any idea of the value?
Have confirmation of authenticity from John Watson. Have the original gauges, wheels, starter, generator (all not on car, but function).
Thanks for all the input.
I have been a member here for a few years and have gotten great information from you guys.
I will be selling my 1964 Super Seven and wanted to get thoughts on the best place to sell it.
Thanks
Shannon
I have a 1964 Lotus S-2 with the intake and exhaust manifold on the same side. Have replaced the gasket but continue to have a slight leak in one small place on the exhaust side. Any ideas on how to repair without a new header? It is original and would like to preserve, if possible.
Got the differential repaired and reinforced but the mechanic stated I needed to replace the seals. Are there any threads on removing the rear axle to replace the seals? If not, could sure use some help on technique.
Thanks
Shannon
