Smithengineered
  1. SkyDrive Sold. Speedometer still available
  2. The SkyDrive is in place of the electronic speedo drive in the transmission.
  3. If you are running an electronic Speedo it can be wired directly into your existing harness that plugs into the back of your Speedo. It just requires a speed signal, constant power supply and a ground.
  4. If purchasing both together I can do $350 plus shipping.
  5. Caterham Seven speedo with 2419 miles and in excellent condition! With bracket. Does not come with harness. $225 plus shipping Sold- Skydrive GPS Electronic Speedometer interface $185 plus shipping.
  6. Thanks for the link! Appears that it is .6” taller.
  7. Wouldn’t a 45 series tire on a 16” rim be equivalent to a 50 on a 15” rim?
  8. Sorry I meant the current wheels are 16x7 et19. I know if I drop to a 15” wheel that in the front they would need to stay 15x7 et19 with a tire size of 205/50/15. The rears I’d like to go with a 8” wide wheel with a 225/50/15 tire.
  9. I think I’ve got it figured out. If I went with 15x8 at a ET 0 and 225 width tire I’m adding roughly 1 5/8” to the outside width on the rear.
  10. yikes this wheel offset stuff is giving me a headache lol. Since I’m dropping down from a 16 205/45 to a 15” shouldn’t the tire go up to a 205/50 to make up for the loss of wheel diameter? The rears Ideally I’d like to go to a 225 if I could go to a 15x8, but still need to figure offset. Thanks
  11. I was incorrect. They are 15x7 wheels et19. I’d like to go 15x8 on the rear. Is it safe to assume that a et19 will actually be a deeper dish and will stick out father on the outside since it’s a wider wheel?
  12. Anyone have good wheel offset/width advice for some 15” minilite wheels? Reading online gives me about 1000 different answers. I have a SV chassis with the de deion rear setup. Current wheels appear to be 8” wide with 205/45 16. I like the look of the deeper dish so ideally I’d like to go as deep dish as possible without fouling the front wings or sticking out in the rear. Anyone that can lead me in the right direction it would be much appreciated! Thanks!
  13. Soft bits long nose shower cap for SV chassis. Located in Taylorsville, KY $160 shipped
  14. Anyone have a set of these mirror mounts they want to part with or know of a US supplier of a similar design before I order from DPR?
