new2 7s Posted July 8, 2007 Posted July 8, 2007 I have decided to place my 1700 Crossflow motor up for sale, here are the details: Reasonable offers will be considered. The details of the motor are as follows: 1700cc 711m Block The heads intake and exhaust ports were polished professionally, bench flowed for accuracy. The block and head have been pressure tested and mag'd and come back tight and clean. Compression averages between 145 and 155 for all 4 cylinders 244 Kent Cam 2x40 DCOE sidedraught carbs - all jets and chokes match. Lotus-Holbay valve cover Balanced rods and crank Dry Sump Oil system w/ custom 2 gallon tank 4x1 Headers and High flow exhaust system Single wire 100 amp alternator Lucas - Pertronix distributor w/ 8mm wires w/ Lucas coil Lucas starter, fully rebuilt with a heat shield so it starts even when hot. 135 tooth lightened flywheel with fresh clutch and pressure plate. The motor is fresh, there are 200 miles street driving time no track time. The asking price with the dry sump system will be $6,500 without dry sump system the asking price is $5,000. The transmission is not included, but the clutch assembly is included. The motor is very strong, tight and fast. The carbs are balance, the timing is set at 8 degrees advance. Reasonable offers will be considered.
