Anaximander Posted February 16, 2015 Posted February 16, 2015 (edited) Sold my M-Spec Storker so I have a like new single axle (3500 pound) 6x12' trailer with custom ramps designed to put your seven on and be able to tow it with a vehicle that has a 3500 pound towing capacity. The trailer weighs approximately 1200 pounds with the custom ramps and has a total payload capacity of 2128 pounds. The custom ramps were professionally fabricated to allow a very shallow ramp and have built-in strong metal supports. The ramps have holders welded onto the trailer to be stowed on the outsides of the trailer securely without tie downs while transporting your car. The custom ramps do not protrude out farther than the wheels. The fold down regular ramp has been reinforced for your car and is drilled for bolts to temporarily bind to the custom ramps for a secure setup. All three tires are top of the line trailer radials. The trailer tracks beautifully. Edited March 11, 2015 by Astro Bob Add Picture
Anaximander Posted March 8, 2015 Author Posted March 8, 2015 (edited) Bump. It is starting to look a lot like Spring is coming. Here is a trailer that is low in cost yet high in performance for very little money. Edited March 11, 2015 by Astro Bob
Anaximander Posted March 11, 2015 Author Posted March 11, 2015 The trailer has been sold. It went however to someone with 4 wheeler off-road vehicles rather than a seven . All of that money and engineering for the shallow ramps. The purchaser wants the ramps so maybe they will get used. Thanks for your considerations.
