rear axle seal replacement
newtoit
Shannon, for anyone to offer a suggestion we will need to know what kind of rear end is in the car, what axle seal you are referring to, and the make and vintage of the car. For instance, on a Caterham built in 2001 there is a side seal in the Ford differential, and two grease seals in the hub bearing carrier.
