GCarlson Posted November 30, 2015 Posted November 30, 2015 I am looking at reinstalling a down-blow type cabin heater in my Ford Super Seven. Need help with plumbing, pictures would be great. I suspect the water outlet is on the water pump, and the return is on the intake manifold. If correct, what threads for barbs will exist there and what would be the appropriate hose ID? Will a simple non-bypass valve be appropriate, since those two ports are blocked now? Thanks! Gregg Carlson Tulsa, OK
