96fvee Posted April 15, 2016 Share Posted April 15, 2016 (edited) i'm looking to fit a quick release wheel on my seven series 2 replica.( spitfire shaft with an adapter and wheel from a company called astrali ). what have you used to set up your own car. I know so far that NRG doesn't make one large enough to work on an older style wheel . I've a 6 bolt pattern , 2 inches apart between the bolt holes on a wheel with a 3 1/2 center and 4 inch outer circle where bolts mount the wheel to hub. I prefer not to cut and weld the steering shaft if I can help it. what has anyone come across that I could use ? thanks, bill c. Edited April 15, 2016 by 96fvee Link to comment Share on other sites More sharing options...
rzempel Posted April 16, 2016 Share Posted April 16, 2016 (edited) What is the shaft sourced from? Sorry, just realized you already answered that. What is the diameter and spline count? A release for pinto or vw might be the same splines. The spline pattern is the real key. Randall Edited April 16, 2016 by rzempel Link to comment Share on other sites More sharing options...
geoz3 Posted April 17, 2016 Share Posted April 17, 2016 PM sent George Link to comment Share on other sites More sharing options...
