Oddbrit Posted December 18, 2023 Author Share Posted December 18, 2023 Thanks to all for the input. Think I can make me way through the problem now! Link to comment Share on other sites More sharing options...
Oddbrit Posted February 15 Author Share Posted February 15 Well I finally got around to addressing. Since I changed rear end gears I tracked down a new 22T speedo driven gear so Zi did not have to dig out the broken quill 9in the old one. I bought some 1/8" square key materials and filled down to the width I measures with calipers on the old quill (0.118"). Found it still didn't because it was catching on edges. After looking at old quill I noticed edges are rounded. Few more minutes with file and sandpaper and I had a nice fit in both ends.\ While cleaning I picked up my old speedo gear, fastened a set of small vice grips to the single piece of speedo cable wire hanging out. Low and behold the cable popped out. It appears it was only in about 1/8" so now I have a good used speedo gear for a 4.11 rear. Also found speedo was tight in it's movement so sent it off for rebuilt. Again thanks all! Link to comment Share on other sites More sharing options...
