Chris D Posted September 8, 2024 Posted September 8, 2024 1961 Series 2 Lotus Seven. Serial number SB1125 with log books from the early 1980’s. Legal with all race groups and recently raced with SVRA, HSR, VRG, Lime Rock Festival and VSCCA with incredible race record. Complete Rebuild 2022 with updated cage, chassis, fuel system, brakes. Fresh built LEGAL 1500 non crossflow. All steel internals with Fresh Super Close ratio trans. Minimum weight at 1025 pounds. One of the fastest and best professional builds available. Includes: Engine: Original build 2022 with 10 events. Dyno development results available for 2022/23/24. 2737 Block, steel crank, Carrilo rods, CP pistons/low friction Total Seal rings. Dry sump oiling system. Head: new 2024 - valves/Beehive springs lt. wt. retainers – flow box development results available. Weber DCOE 40’s with match lowed Al intake, Uni filters. Al flywheel with 7 ¼” Ap clutch/pressure plate and hydraulic throw out bearing. Ceramic coated progressive tube headers. Lite wt Al roller rockers with proper valve scrub geometry. MSD electronic ignition and rev Limiter – new MSD wires. Single wire alternator with cog belt crank/water pump underdrive pulleys. Remote Surge tank. Trans – updated 2024 legal super close ratio- specs available. Custom remote shifter. New driveshaft/yoke/U-joints. Rear axle: 3.9 Torsen Diff. Rear reinforced/bridged 3 link Spriget axle. Dual bearing hubs – HD axles. ARP Wheel studs Suspension: New 2024 custom Aluminum body double adjustable coil overs with dampers build specifically for the car/ corner weights. Springs ordered based on motion ratio and sprung/unsprung natural frequency - calcs available. Frt - New upper/lower A Arms. New uprights/trunions/ new big bearing spindles /bushings 2023. Brakes: frt – new Girling LF14 calipers/rotors. Rear - Spriget 8” drums – drums/pads matched. All Dash 3 Aero. New Tilton Masters. Brake balance bar. Fuel safe 5 gal. fuel cell with custom mounting. Facet high flow fuel pump, fuel pressure regulator with gauge all new Dash 6 Aeroquip lines and fittings. Kirky seat. LifeLine 10 # /4 nozzle fire system. Removable leather wheel. Autometer gauges. Memory 8” tack with shift lite. Inovate Wide range O2, OMP Belts. Race Panasorts on car. Lots more. Complete spares package available including: 2 sets of race Panasports with race and rains. Complete fronts suspension with upper and lower A Arms, Uprights Big bearing spindles/bearings, calipers, rotors, pads and bushings. Rear brake assemblies. Springs. Rear diffs. Engine parts: Blocks, Fresh Race head – too much to list. PhotoBucket of dozens of pics available to those who contact me. Chris D 585 330 5456 cdmad4494@aol.com $39,000/B/O IMG_2769.HEIC
