Donnie Posted October 24, 2024 Posted October 24, 2024 Need a diagram utilizing motor terminal numbers (not colors), switch terminal numbers (35927) and relay terminal numbers. I wired it without the relay and it blew fuses. Switch is probably a knock off. Thanks in advance.
Jbrueckh Posted October 24, 2024 Posted October 24, 2024 Check these out and see if they help. Windscreen_Wiper_system.doc WiperSwitchMotor_logic.pdf windscreen%20wiper%20motor%20manual.pdf
Donnie Posted October 27, 2024 Author Posted October 27, 2024 On 10/23/2024 at 8:32 PM, Jbrueckh said: Check these out and see if they help. Windscreen_Wiper_system.doc 76.5 kB · 8 downloads WiperSwitchMotor_logic.pdf 418.07 kB · 4 downloads windscreen%20wiper%20motor%20manual.pdf 190.7 kB · 2 downloads
