2000 WCM Ultralite For Sale **SOLD**
**SOLD**
FOR SALE:  WCM (World Class Motorsports) Ultralite Lotus Seven replica kit car.  This is a Lotus Seven replica with an S2000 drivetrain.
Engine: 240hp F20/22c from an S2000 (dynod at 195whp)
Transmission: 6 spd manual from an S2000
ECU: Hondata Pro - dyno tuned to make ~195whp
Rear-end: Subaru LSD with 4.11 ratio
Brakes: Wilwood on all 4 corners, plus brake bias adjuster
Wheels: 17" with 215 up front and 245 in back (Bridgestone RE71s)
Suspension: QA1 (have stock shocks as well)
Title: Clean California Title, Street Legal SB100 registration with no smog required.
Tons of spares including a diff, alternator, original shocks, original ECU, valve cover, etc...
Also Includes a lightweight open trailer so you can take it to the track or autocross. The trailer is a former heavy duty wave runner trailer converted with wood planks/ramps.
I purchased this car from a fellow user (@rnr), which he and jrankin did a lot of 'sorting'.   RNR had a blog series + various videos you can find from when he had it, detailing a lot of it's history.  Since I've owned it (~8 years) I have done various maintenance tasks:
-Car has been corner weighted for me (155) and alignment last done by Custom Alignment in mountain view
-Pedal box was adjustable via slider mechanism, but is now bolted in place for safety.  It's setup for somebody at least 5'7 - 6'0.  One could easily revert this modification or adjust it for their set height
-Head was rebuilt about a year into owning it, along with the baffled oil pan being installed
-All spherical rod end links (aka heim joints) have been replaced a couple years back by trackspec in Fremont.  If you ever look for a WCM this is one of those things that need major servicing
-Fuel pump and filter replaced a couple months ago
*Some notable changes from a stock WCM:  custom cage, qa1 shocks, diff support, a/f gauge, shift light, baffled oil pan, lithium battery
Selling because I don't drive it often and feel somebody else should get to enjoy it.  It was originally supposed to be my track car, but haven't taken it to the track in many years.  I would guess it's logged 100 miles (at best) in the past year, maybe 500 total since 2020.  It does get started on a consistent basis and is put on a battery tender.
$25,000
NO TRADES
Edited by sf_wcm
  • sf_wcm changed the title to 2000 WCM Ultralite For Sale **SOLD**
