Chris D Posted November 11, 2025 Posted November 11, 2025 Complete 1500 cc Non Cross Flow engine from One of the Fastest Legal Vintage Lotus Sevens in the country. TURN KEY - Legal with all race groups and recently raced with SVRA, HSR, VRG, Lime Rock Festival and VSCCA with incredible race Win record. Complete NEW build in 2022 and freshened in 2024 with a new cylinder head, bearings, Rings etc. with only Dyno time and 4 races. All steel internals. Professional build. Build Sheets/Documentation/Receipts available for review with Dyno development results available for 2022/23/24. 2737 Block, steel crank, Carrilo rods, CP pistons/low friction Total Seal rings. Dry sump oiling system. Aluminum pan with Titan pump. Dry Sump 6 Qt tank and Aero lines included. Cog belt crank/water pump under drive pulleys. Adjustable cam gear with front cover modified for easy dyno adjustments. Head: new 2024 - with valves/Beehive springs light. wt. retainers – Ports/Valves/Cam flow box development results available. Roller Al Rocker arms with Alloy push rods set for proper Scrub. Weber DCOE 40’s with matched Aluminum intake. Alloy valve cover. Al flywheel- 10 pounds with 7 ¼” with Tilton clutch/pressure plate. MSD electronic ignition with MSD 6AL with rev Limiter and new MSD wires included. Al rear engine plate for conversion to Hewland/Spriget lightweight tranny available with Flywheel assembly and Tilton starter. Spares - New: Cometic MSX head gaskets, Intake and exhaust valves, Belts, Plugs, Miscellaneous gaskets... Sold the Race Car so Engine needs to GO. $13,000 / Best Offer Can bring to the Summit Point VRG event Nov 14/15 for review of dyno and build sheet specs. Thanks for looking. Call Chris D 585 330 5.456 cdmad4494@aol.com IMG_0789.HEIC IMG_0792.HEIC IMG_0790.HEIC
