locostv8 Posted August 22, 2006 Posted August 22, 2006 Something I would like to pass on. I had to drill some 2" holes thru the winch mount push bar assy on my Crawler/Jeep/Truck/thingy and nearly took my arm off when the drill bit mounted in the hole saw broke. Not smart enough to evaluate the cause I replaced the drill bit and broke another within seconds. It is important that the locating piece of the hole saw be round smooth material, the shank of the drill or as I do now a smooth mandrel, not the flutes of a drill bit. The flutes will catch then bind and break leaving the hole saw running amuck.
