andrew7 Posted November 30, 2007 Posted November 30, 2007 For the past 2 years I found myself in the wrong gear, by accident starting in 3rd or cruising in 5th, just forgetting how many clicks I did. All the information my cluster has why not a gear change indicator? I been looking through the R1 motorcycle forums and found a lot of important info, things I need to change during the winter. I figured you guys would like to know about this. http://www.datatool-1st.co.uk/html/electronic.html Its available in the US and I found Acumen manufactures one but theirs is $160. I'll know what gear I'm in next year, how about you?
ptrxly Posted December 2, 2007 Posted December 2, 2007 This is what I am using with the Hayabusa motor and generally,it works fine. -nice big display. http://www.xtsportbikeaccessories.com/GIpro.html $169Cdn. Before I added the gear position indicator I would never know if I was in 5th or 6th and often found myself trying to shift into 'seventh'. The only issue that I have now with the GIpro is that it sometimes reads 5th when it is really in 6th. It has a learning mode so I will try that in the spring. I also will mount it on the steering wheel along with a shift light. Has anyone used one of these: http://www.raptorperformance.com/ Peter
BusaLoco Posted December 3, 2007 Posted December 3, 2007 Hi Ptr What are you doing for reverse these days? As you know I've been thrashing around a lot of electric ideas all these long years. ... But the days of dreaming electrically are soon to be in the past. Last week I bit the bullet and ordered the Quaife Reverse Box, Breather Bottle and Synthetic Lube ... $1,932 Can (after conversion from BP) ... a real deal too when you order it direct from England ... Just $530 in taxes and shipping! ... And Bonus ... I'll be able to do $109MPH Backwards! Oh, Be still my heart!
ptrxly Posted December 6, 2007 Posted December 6, 2007 Hi Jim, Right now a powered reverse is a bit lower down on my priority list. I'm very careful on where I park and now don't feel embarassed about pushing my car whenever I have to. The lack of a powered reverse is not the problem that I initially thought it would be. When I do make the commitment, I will probably go the cheap route and do it electrically. I have just put a deposit on a new gokart for my son and I will pick up a used one for me, so funds this year for motorsports have expired. This winter, again, the priority is to make doors, a roof and trunk lid. Cheers, Peter
