solder_guy Posted July 18, 2008 Posted July 18, 2008 (edited) Toyota Axle Website: http://www.norbie.net/toyotaaxle/ As an example of how to decipher Toyota axle codes: The '80 Supra from which I grabbed the solid rear axle has code "F312" which corresponds to: a 7.5" Ring Gear, a 3.909 gear ratio, and 2 pinions with no LSD. Rob Copied from celicasupra.com: check the firewall vin plate. ----------------------------------------------------- First Digit: (Ring Gear Diameter) Second & Third Digits: (Gear Ratio) Fourth Digit: (# of Pinion Gears ... Limited Slip (yes/no) ----------------------------------------------------- A = 138 mm B = 145 mm C = 6.25 " D = 6.62" E = 7.1" F = 7.5" G = 8" H = 9" J = 9.25" K = 9.5" L = 10.5" M = 12.5" N = 13.5" P = 14" R = 162 mm S = 6.38" T = 6.7" U = 6" V = 10.6" W = 15.5" X = 142 mm Y = 158 mm ----------------------------------------------------- 01 = 3.30 02 = 3.36 03 = 3.545 04 = 3.556 05 = 3.70 06 = 3.889 07 = 3.90 08 = 4.111 09 = 4.222 10 = 4.375 11 = 4.444 12 = 4.625 13 = 4.79 14 = 4.875 15 = 5.125 16 = 5.286 17 = 5.60 18 = 5.714 19 = 5.833 20 = 6.167 21 = 6.667 22 = 6.78 23 = 6.833 24 = 7.64 25 = 4.556 26 = 5.571 27 = 3.364 28 = 4.30 29 = 4.10 30 = 3.727 31 = 3.909 32 = 6.591 or 5.583 33 = 7.503 or 5.583 34 = 6.781 or 4.786 35 = 7.636 or 5.60 36 = 4.778 37 = 3.583 38 = 3.417 ----------------------------------------------------- 2 = 2 Pinions/No LSD 3 = 2 Pinions /Yes LSD 4 = 4 Pinions/No LSD (4WD) 5 = 4 Pinions/Yes LSD (4WD) Edited June 28, 2009 by solder_guy
