Ebay Find: NOS Pair H4 Cibie Lights OSCAR Concave 7" 2 Lamps 180mm
Haven't seen a post lately so decided to put up a few....
Not mine
Quote from seller:
_____________________________________________________________________________________
Item number: 350133068330
http://cgi.ebay.com/ebaymotors/NOS-Pair-H4-Cibie-Lights-OSCAR-Concave-7-2-Lamps-180mm_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a3Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem350133068330
It reads Cibie H-4 IODE, HCR, E2 ,20, 337 , 24
They are H4 with High and low beam 60/55 watt 12 Volt
The glass is 5 3/4 Inch diameter (150mm )
The headlight assembly is aprox 7 inches wide(180mm) x 4 1/2 inches deep(115mm) and stands 7 3/4 inchs high (195mm) on its base.
The rim has a nice chrome finish and the base mounting hardware and bracket are a gold/zinc finish.
The lamp housing has a Gray Enamel finish and there are two lens mounting tabs on the housing so the lamp assembly can be flipped 180 degrees, The mounting base is on the bottom but can be fliped for on top use and has a 30 degree swivel range using a 7/16 inch (10 mm ) mounting stud
