7ishNZ Posted July 2, 2009 Share Posted July 2, 2009 What are your thoughts on having a slipper clutch in a bEC.... a good idea or not? I have a Yamaha R1 with an option for a slipper unit. Link to comment Share on other sites More sharing options...
R1 Seven Posted July 2, 2009 Share Posted July 2, 2009 I don't know that it is needed with a BEC. My car does not seem to drag the rear tires while going down through the gears under heavy braking. I have no idea as to whether they are more or less durable than a standard clutch. That is probably more important in a BEC. Link to comment Share on other sites More sharing options...
7ishNZ Posted July 3, 2009 Author Share Posted July 3, 2009 Thanks... I think I'll stick to the stock clutch with barnett springs.. Link to comment Share on other sites More sharing options...
R1 Seven Posted July 7, 2009 Share Posted July 7, 2009 That is the same setup I am running and it has been great so far. Just be sure to run motorcycle specific oil, or you may have some clutch slippage under hard acceleration. Link to comment Share on other sites More sharing options...
