About the cargo box:
I forgot to mention: There is a piece of 1 X 1 tubing permenantly bolted under the floor (thru the frame). The 1 X 1 tubing that support the boxes are bolted on the side of the permanent tubing. It is easier to unbolt the supports from under the car rather than inside the passenger footwell.
  • 7 months later...
I recently came across a weber alpha ignition kit for a zetec but a plug has been cut off the harness . It has four exposed wire ends.
I'm not familiar with Weber wiring codes so if you could clarify the functions of the wires. My guesses are;
1, blue with white tracer....shift light?
2, large black....Ground?
3, large white....12v constant?
4,yellow....12v switched?
thanks
m
Edit. Got those wires sussed, but now have two white wires on the same sub harness. Hopefully they're a splice.
Edited by pi7ot
