Does anyone run a 205 tire on a 6 inch rim?
Cold Inflation Pressures
Optimum cold inflation pressures are chosen to achieve optimum hot inflation
pressures.
Optimum cold inflation pressures are determined by: 1. event distance and, 2. vehicle
weight and 3. camber settings. Pressures shown below are for inflation with
compressed air.
Event Distance - Dry Tarmac
Vehicle Weight 4 laps or more Very short - hillclimbs or maximum
3 laps.
Very Light
Light 800kg - 1000kg 20 - 26 psi 21 - 28 psi
Heavy 1000 - 1400kg 23 - 27 psi 26 - 32 psi
Very Heavy > 1400kg 27 - 35 psi 31 - 38 psi
Hot Inflation Pressures
Hot inflation pressures indicate the suitability of the cold inflation pressures. Where
hot pressures are too low, start with a higher cold inflation pressure or vice-versa.
Pressures shown below are for inflation with compressed air.
Vehicle Weight Optimum Hot Inflation Pressures
Very Light
Light 800kg - 1000kg 24 - 32 psi
Heavy 1000kg - 1400kg 28 - 40 psi
Very Heavy > 1400kg 37 - 42 psi
Hot Inflation Pressures Guide:
The hot inflation pressures shown above have a large range. This takes into account
the variances in vehicle weights within the ranges shown, as well as axle weights, for
example: a front-engine, rear-wheel-drive vehicle with a front weight bias will usually
give best results with hot pressures that are 2-4psi higher on the front axle compared
to the rear axle.
Changing hot inflation pressures by small amounts ( 1-4psi ) can be used to
fine-tune handling:
Changing hot inflation pressures to change handling bias should be
used for fine-tuning only. Improving overall grip levels should be done by
tuning spring rates, sway bars, suspension geometry etc., using lap times and
pyrometer readings to asses changes.
Reduce Oversteer reduce rear axle hot inflation pressure
Increase Oversteer increase rear axle hot inflation pressure
Reduce Understeer reduce front axle hot inflation pressure
Increase Understeer increase front axle hot inflation pressure
Hot Inflation Pressures NOTE: Tyres with full tread depths used on dry tracks will
have more tread flex and therefore more heat build-up compared to tyres with
reduced tread depths. One result of this heat build-up is slightly increased pressure
build-up. The amount of pressure build-up will decrease as tread depth decreases.
Hot & Cold Inflation Pressures for Proxes RA1 & Proxes R888: Due to a casing
construction that has less sidewall deflection compared to the Proxes RA1, the
Proxes R888 will provide optimum performance with hot and cold inflation pressures
which are 2 - 4psi lower compared to the Proxes RA1 with the same using conditions.
WET CONDITIONS & INFLATION PRESSURES
For wet tracks (STANDING WATER) increase pressures by 4-10 psi compared to
dry track pressures. Increasing the pressure for wet tracks makes the tyre's contact
patch smaller, making the tyre less susceptible to aquaplaning.
There is less heat build-up on wet tracks, therefore less pressure build-up. This is
another reason cold inflation pressures need to be higher than those used for dry
conditions.
For optimum performance on tracks where there is standing water, tyres with new
depth or close to new tread depth will provide optimum performance. Buffed or
worn tyres (3 - 1.5mm tread depth) will be susceptible to aquaplaning where
there is standing water.
It is recommended that tyres used on wet or damp tracks are given a short
"scrubbing-in" session before they are used competitively to remove the layer of
mould release on the new tyres. Without "scrubbing-in" the tyres will be slippery until
this layer of mould release agent is worn away.
Camber Settings
Toyo motor sport radials will provide optimum cornering grip with camber settings
between negative 3 and 6 degrees on steer axles. Where adjustment is possible,
negative camber on drive axles will also improve cornering grip. Optimum camber
angles will provide optimum cornering grip, and therefore will be an important
contributing factor for improving lap times.
NOTE: On some vehicles a lack of negative camber can over-heat the outside tread
shoulder causing grip levels to drop-off suddenly and in some cases cause blistering
of the outside tread shoulder. Large heavy, front engine cars are most susceptible to
this type of tyre damage.
CAMBER SETTINGS & INFLATION PRESSURES
Where camber adjustment is limited or class rules limit the amount of negative
camber allowed, increasing cold inflation pressures may help to prevent the outside
tread shoulder over-heating. This also applies to vehicles that are used on the street
as well as the track, where the camber settings are a compromise for this dual
purpose. Where this is the case, adding 3 - 4psi to recommended cold and hot
inflation pressures usually helps to prevent the outside tread shoulder overheating.
Increasing inflation pressures to prevent the outside tread shoulder overheating
where more negative camber is needed for optimum tyre performance and
grip is only recommended where camber adjustment is not possible, and is not always
effective (testing the pressure increase will confirm wether the increased inflation
pressure improves lap times).
Tread Depths & Tyre Performance on wet & dry
surfaces
All grooved motor sport tyres will have some tread flex. On dry surfaces tread flex
reduces overall grip levels and therefore lap times. To optimise dry grip levels with
grooved race tyres, tread flex needs to be minimised. The more groove area or "void"
a tread pattern has, the greater the amount of tread flex there will be in dry conditions.
PROXES RA1 - This pattern has a tread depth of 6mm or >6mm when new and has
enough groove area to be very effective as a "wet" with new tread depth or close to
new tread depth. For optimum dry track performance, buffing will make a large
difference in grip and endurance for the Proxes RA1 and is highly
recommended. Buffing will also provide more even tread wear and a slower wear
rate.
PROXES R888 - This pattern has 5mm of tread depth when new and minimal groove
area on the tread shoulders for optimum dry track performance. Buffing the Proxes
R888 will provide a small improvement for cornering grip on dry tracks.
PROXES RR1 - This tyre is designed for wet weather use only and will provide
optimum aquaplaning resistance with new tread depths. Aquaplaning resistance
reduces as tread wears. The tread compound of this tyre will over-heat very quickly
where a dry line begins to appear.
Tread Temperatures
As for most motor sport tyres, Toyo motor sport radials can be slippery when cold.
Caution needs to be exercised until the tyres have had some time to warm-up. For the
Proxes RA1 tread compound and the Proxes R888 & Proxes RS1 "GG" tread
compound, grip levels will be low when the tread temperature is less than 55
degrees Celsius.
Optimum operating temperatures for the Proxes RA1 tread compound and the
Proxes R888 & Proxes RS1 (slick) "GG" tread compound is between 75 and 95
degrees Celsius. Over 100 degrees Celsius, grip levels drop-off rapidly.
Rim widths and tyre performance
Toyo motor sport radials will provide optimum performance where the rim size allows
the sidewall to have little or no protrusion from the rim flange.
Each Toyo motor sport radial product information page includes a link to download a
PDF file that quotes dimensional information, including approved rim widths. Where
possible, use of minimum rim widths should be avoided. For most sizes, optimum
tyre performance will be provided with rim widths that are from the mid point to
the maximum in the range of approved rim widths shown.
Street use
The Toyo Proxes RA1, Proxes R888 & Trampio R8881 are legal for use on public
roads but recommended for competition or use on closed circuits. Grooved, street
legal race tyres are designed for users who need to drive their vehicle to and from the
circuit, and / or where the class regulations specify that street legal tyres must be
used.
When compared to high performance or ultra-high performance tyres, when used on
public roads, Toyo motor sport radials will:
1. have comparatively poor ride comfort. Toyo motor sport radials have a steel
sidewall ply to minimise sidewall deflection for optimum cornering grip.
2. be susceptible to "tram-lining" / "tracking". The casing stiffness provided by the steel
sidewall ply and wide belt packages used on Toyo motor sport radials make them
susceptible to tram-lining caused by road irregularities common on public roads.
3. have faster tread wear. The tread compounds used on Toyo motor sport radials
provide much higher grip levels compared to high performance or ultra-high
performance tyres rather than long tread life.
4. be slippery when cold. Due to the tread compounds & construction types, grip levels
will be low until the tyres have had some warming-up. This will be especially
noticeable in cold and / or rainy conditions.
5. be susceptible to aquaplaning when used with low tread depths (3 -1.5mm) on wet
roads, especially in heavy rain conditions. Users need to exercise caution in these
conditions with careful monitoring of vehicle speed to avoid aquaplaning. The
Proxes RA1 pattern is the exception. The Proxes RA1 has a void ratio that makes it
resistant to aquaplaning, where tread depths are >4.5mm.
My car came with a setup for running Hoosier bias-ply slicks. When on the slicks, I run 7" in front and 8" in back, on 13x6 wheels all around. I've also run the car on Hoosier R6 DOT track tires, 185 in the front and 205s in the rear. The guy who mounts my tires had no issues whatsoever with the 205s, and to my eye they look to be a much better fit than the 8" slicks.
(I do, however, notice a substantial difference in handling. My scale shows that the DOT tires add about 7 pounds per corner, and that added weight dramatically changes how the car feels on track. The car goes from feeling "squirty" to "sluggish.")
