Anyone out there running a Hayabusa that has pulled a freeze plug to put in a second water temp sensor? Would love to know the size and pitch.
My dash gauge needs a specific sensor, its different than the stock sensor. The ECU uses the stock sensor to adjust richness (when cold etc), so I do not want to mess with that one.
  • 1 year later...
Just in case anyone ever needs to know. its 22mm X 1.5.
Hand to re-tap my block this week and finally got the right one after buying a few different sizes. Note this is for a K8. After talking to a few Hayabusa guys I found out that the older models are smaller. Do not know that size but I know its smaller. Got the wrong plug first and it did not fit.
