Robert O. Urfer Posted March 20, 2007 Posted March 20, 2007 Some interesting info from Dennis hedges. Front alignment 1/16 per side toe in 1/4 to 1/2 negative camber 3 degrees positive caster he also stocks the suspension bushings which i have a set being sent. I may get this thing together sooner than I thought. http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif
solder_guy Posted March 20, 2007 Posted March 20, 2007 Good to know .. thanks! Take pics of the bushings when you get them. Are you going to replace the ball joints too? Note any part numbers. Rob Mitchell solder_guy2007-03-20 17:51:37
Robert O. Urfer Posted March 20, 2007 Author Posted March 20, 2007 I will be replacing the ball joints as well. I will be ordering those from the local auto parts store tomorrow. uppers: Big A # PRC ES 150 R ??? lowers: big A # PRC 10230 seal power # 801-11230 moog# K 8036 These are the numbers I have I am sure any of them will work.
