sdca7 Posted May 20, 2011 Posted May 20, 2011 I am troubleshooting a sensor problem on my Stack dash. Is there anyone here with a Stack dash setup and digital oil pressure sender that could do the following: What does the oil pressure read when you turn on the ignition, but don't start the car? Mine is reading -99, which from the Stack manual means either a bad sensor or a wiring problem. Thanks to anyone who could check this out on their car! Justin
sdca7 Posted May 23, 2011 Author Posted May 23, 2011 Thanks, Speedcraft! That is what I suspected would be the case. I have ruled out the oil sender as the problem. It looks like I have a short somewhere in the wiring harness. Thanks again!
