jlumba81 Posted June 11, 2011 Share Posted June 11, 2011 I decided to follow the advice of a fellow 7 owner to install a filler cap on the T-9 cover. Filler cap off amazon.com for $35 Filler cap placement on trans cover Pilot hole drilled Need a better hole saw but it got the work done Cleaned up the hole and prepped area for welding Link to comment Share on other sites More sharing options...
jlumba81 Posted June 11, 2011 Author Share Posted June 11, 2011 Magnet to hold filler cap bung in place I need more practice its a bit messy but it works. Filler cap fitted to bung Rattlecan black for rust prevention Link to comment Share on other sites More sharing options...
jlumba81 Posted June 11, 2011 Author Share Posted June 11, 2011 While I was at it I cut down a 10mm allen fit the transmission fill plug. Paper gasket for the trans cover broke in half. Used some axle rtv that was lying around to make a seal Trans cover reinstalled. Two rear bolts are a PITA. Also don't forget to keep track of all bolts when removing the cover. I counted 9 and thought I dropped one in the trans, but found it on the side of the transmission. Using pump siphon to remove the old fluid. Made a mistake and put redline 75w-90 GL-5 oil and had to remove it. Ended up buying some royal purple 75w-90 oil GL-4, GL-5 rating until the proper GL-4 oil arrives next week. Link to comment Share on other sites More sharing options...
lancylad Posted June 11, 2011 Share Posted June 11, 2011 good thread, why didn't I think of that!!! Another mod I will have to do.. Link to comment Share on other sites More sharing options...
athens7 Posted June 13, 2011 Share Posted June 13, 2011 Well done-I've had computer difficulties and haven't been able to post, but your solution is the same as mine, with the only difference being I used a bung the same size as an o2 sensor thread. While you're at it, now is a good time to cut a metal rod to length for a dipstick and mark the fluid level; it will make maintenance easier. Link to comment Share on other sites More sharing options...
Ross Posted June 13, 2011 Share Posted June 13, 2011 Good modification...thanks for your article. which item? Part number, manufacturer on Amazon.com? Dont see a filler cap bung in any of the adds? Bob Link to comment Share on other sites More sharing options...
jlumba81 Posted June 13, 2011 Author Share Posted June 13, 2011 I used a Pro-werks C73-750 2" Black Aluminum Fill Cap with Steel Weld Bung. They have a few other sizes. I believe I used 'weld bung' when searching amazon. athens7- Thanks for reminding me. I think I'll make a dipstick when I replace my leaking speedogear oil seal and my fuel filter. I ended up getting the fill cap instead of an o2 bung because I'd have to order an o2 online and I wanted something w a bigger opening. Link to comment Share on other sites More sharing options...
