I have for sale a type 9 transmission. I was told the millage was 72k. the deal is i have cut the shifter remote off to shorten it. i was planning on using it in my duratec mg midget swap but im going to use a different transmission now. Also the input shaft has been cut to fit with the quad 4 rods bellhousing i had bought. its not a perfectly straight cut so will most likely need to be trued up on a lathe or similar. With the shifter remote cut off you could finish shortening it or weld it back as stock. i have not cut the shifter rod and i retained both bushings when i started shortening it. also if your type 9 has high miles or in bad shape you could buy this one and just use your tail shaft. given the modifications to the transmission im only asking $300 for it. plus exact shipping to your loacation. Im located in south carolina. If you are local you can pick this up in person. thanks This has been sold
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3614.jpg
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3615.jpg
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3616.jpg
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3618.jpg
Edited by seanb
more pictures
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3634.jpg
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3635.jpg
http://i27.photobucket.com/albums/c171/seanbartsch/IMG_3636.jpg
