mcfandango Posted March 27, 2012 Posted March 27, 2012 (edited) Time has come and I tossed in the towel on the Coveland "kit". The frame is long gone and I need to recover some garage space. All prices are OBO. All pictures can be found here. http://www.mcfandango.org/pictures/main.php?g2_itemId=1048 Lower Control arm kit, Kinetic, I have only tacked the outer ball joint plates, otherwise pretty much untouched. This will include the lower ball joints. ~100 more if you want the 94 spindle/hubs as well. Rear Coilovers that are for sale 300 bucks. No miles on them. Just been used to hold the frame up in the rear. QA1 DR4855 Proma Star Single Adjustable Shock Mounting Type: Bearing Mounted QAPDR4855B QA1 9" Coil Springs- Powdercoated Rate per Inch: 450 lbs. Edited May 9, 2012 by mcfandango Sod stuff
