breezy7 Posted June 4, 2012 Posted June 4, 2012 I want to change the serpentine belt on my Zetec SVT and was wondering what and where others have purchased. Does the belt from the stock SVT work? I think the belt tensioner is in a different location so not sure I can use the stock belt. If nothing else I will take off the old belt and take it to my local parts store, did that when replacing radiator and heater hoses. Mike
Klasik-69 Posted June 4, 2012 Posted June 4, 2012 I have a spare belt for my Zetec and when I get over to my shop I'll look it up to give you the part number. It may or may not be the same as yours. Mine is an 04 Zetec motor prepared by Jon @ Caterham USA. Also, you may be aware that most belts have part numbers written on them. However, in the case of serpentine belts, the back of the belts usually ride on an idler pulley or the back of some other pulley which usually burns off the id markers.
glenntwincam Posted June 4, 2012 Posted June 4, 2012 (edited) goodyear p/n 4060560 or 6pk1420. most parts stores should have it for about $15. they can also cross ref. to gates p/n . it fits a lot of older GM & chrysler products. we have a SVT powered S3 , engine was set up by cat/usa. to be safe take the old belt with you. Edited June 5, 2012 by glenntwincam
Klasik-69 Posted June 5, 2012 Posted June 5, 2012 Sorry I didn't get back with you sooner but its as glenntwincam stated. Mine is the Goodyear belt as well.
