Stalker number 17 is being replaced!
Super Stalker #65 is about to hit the road…
If you are new to the idea of a Stalker, check out Brunton Automotive (http://www.bruntonauto.com/). This is a cleverly designed and extremely well-fabricated chassis with close to 200bhp and unbelievable torque in a 1,500lb package. You will feel comfortable, safe and exhilarated, and you will realize it is practical to realize your dream.
• Licensed in British Columbia Canada
• Completed in 2004 by Al Beix
o New crate HO 3.4 from GM + Holley 4 barrel
• One additional owner – ca 500 miles
• Ca 4000 miles from build
• Refit in 2011
o Front end conversion
• Wilwood disc brakes
• Updated steering arms/fender stays
• Indicator repeaters added and fenders re-fitted to reduce rock spray
o Rear end conversion
• GrandAm rear discs and functional e Brake
• New Moser axle shafts
o Reconfigured Wilwood master cylinders to match
o Full rollcage (1.5 in DOM) installed
o Hushpower 11s and full exhausts each side
o New clutch release bearing and updated T5 transmission
o Lokar throttle pedal and linkage
o Windshield raised to match roll cage
o Stainless “rock guards” added to rear fenders
o New rear deck and “trunk” created
o Daytime running lights, marker lights and reflectors added
o A lot of general tidying and safety changes
• Ca 1000 miles in summer 2011
This car is now a seriously civilized ride with progressive brakes, no exhaust fumes or noise in the cockpit, vastly reduced wind buffeting and much improved visibility through the higher windshied and a rollbar mounted mirror! With the right shock settings and tire pressures 200-mile days are a breeze.
Auto X’d once recently, it generated smiles all around. Generally it gets thumbs-up from the law, smiles from women and kids and jealous glares from males 20-55!
Having spent without reserve, we tripped over the opportunity to do a build from the ground up. This car can now become someone else’s opportunity to play without needing any work.
Available immediately or make a trip to join as many as 18 “7”s for the weekend of August 4/5 on Vancouver Island and drive it home!
You can pay Brunton $35k, or Mark Scott $50k, save up for a Caterham, or, the first offer of $27,500 takes it.
Pictures at http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=1616
Contact - campbellchris@rocketmail.com
Sold and moving to Montreal. Will be road and track day car.
Ohhh sweet! Some more montreal fun! Can't wait to see it on the track and maybe play with him! hehehe
wonder if it's anyone I know! :)
