Currently California smog exempt and currently registered
Registered via California SB100
Dunnel ZX1 210 HP engine
Weber 45mm DCOE
Dunnel ignition control unit
Dunnel lightweight steel flywheel
Dunnel oil pan with windage tray
MSI ZX1 alternator mount
Water rail kit
MSI expansion tank
ITG air filter
Transmission 5 speed ford T9 with quaife close ratio gears
Quaife limited sip differential
MSI rear radius rod kit
Option Extras that fit this car specifically
15 gallon fuel tank requires removing the trunk liner
Koni spring and shock package (TRACK ONLY)
Rodger Hamlin roll cage
$28,000 or best offer
Please contact Larry or Cheryl 707-448-1282
