In a S3 Caterham in road trim, running 5.5j rims I would run 14 F 18 R. Most 7's that I have driven would bennifit from being MUCH softer on the springs and dampers. The 7 must have body role in order to load the front end up otherwise the front will wash out.
Running slicks we run 10F 14R
Edited by Terry
That is truly interesting, I have found 15 F and 18 R good. I must admit I have not tried less than 15 lbs for fear of rolling a tire off the rim but perhaps that's not likely to happen as the 50 series wall is quite firm.
What diameter rims do you run Terry,
