My twin cam sounds a little like a traction engine on idle sort of a tut tut tut and when revved it runs on for a second or two which transfer into a couple loud backfires when you back out of the gas in 3rd gear. The throttle is not sticking, it returns to the idle position immediately. I used a syncrometer and have both carbs reading the same number.
Any ideas?
When I owned a twin cam two different things did this to me and both were distributer related, vacuum advance issues and the other was the spring loaded rev limiter failing.
check that the choke/venturi has not turned within the carb
Is that what they call the Auxiliary Venturi?
  • 4 weeks later...
Its the venturi mentioned in this article:
http://tedperkins.com/weber_principles.htm
Finally have time to try and sort my problem, first thing I noticed was the venturi mentioned in this article is loose. That's the tube inside the metal ring. If I stick my finger in there I detect slight movement whereas the other three are firm, no movement.
What I can't figure is what fastens this part?
Any help would be greatly appreciated.
There is a little grub screw on the side of the carb body that holds the venturi in place. If the venturi twists a bit in the body it can restrict the fuel flow (or so I have heard)
No grub screws on this carb, mine are 40 DCOE 18 if that makes a difference. I'll keep Googling.
OK I looked at the side and that's almost out of sight underneath with my setup, it will be a so n so to get to. I might have to use a bent screw driver. But if it solves my problem it will be worth it.
Thanks again
No mine is held in with a piece of bent spring steel and after a further check they all have a little play so I'm back to step one :(
