Road Ready
Ford Zetec engine. How long to get oil pressure?
Road Ready replied to Road Ready's topic in General Sevens Discussion
Good news! It's a false alarm. I had apparently disconnected a wire from the oil pressure sensor while searching for a way to reach the oil filter. Oil pressure showing as soon as I reconnected it. Thanks for all the good advice. John -
NC allows us to title a car to the year it's intended to replicate. Ours is a 2007 bild, 50th anniversary edition. It's titled as a 1957 Lotus Seven Replica. John
Long story short, I hit a really big pothole at sufficient speed to break a wheel. I'm on my way to replacing the wheel with the help of Josh at Rocky Mountain Caterham. It seems like a good idea to get the alignment checked. Do I need a special shop/special equipment for that or would a regular alignment shop be able to do it? I'm in western NC
What's the best number to call for parts at Caterham in England?
I'm in Western NC and would love to run with some other Seveners on the BRP sometime. Right now it's closed mostly due to nasty ice stalagmites in the tunnels and some other issues. Think about springtime!
Burt was unable to get the right parts for the pinion gear in my diff. He had to send some stuff back to Burton in England. It's the Ford Sierra diff, built by Quaife. Burt had a very low opinion of the way it was set up. I might end up buying a new diff., having Burt take it apart to be sure it's properly assembled and then install in my car.
Having a car that's road-legal and having it legalized are two different things. When we were working to get my car titled for the first time it had to be inspected, at our place. We worked carefully to be sure that all the lights and horn were working properly. Then the inspector arrived. We noticed that he was wearing a side-arm. It turned out to be a rather different kind of inspection than we were anticipating. An engine block serial number being impossible to see orsee using a mirror or even obtain a clay imprint, we ended up having to post a substantial indemnity bond as one of the hoops we had to leap through. Now were titled as a 1957 Lotus Seven Replica. It works fine for me!
Rocky Mountain Caterham was very helpful. Josh has a hearing impairment that makes e-mail a better option for him. They have a lot of diff parts in stock. I talked to Ross, Josh's father. There's also Burton Power in the UK. Amazingly, Burt, my diff guy, was able to order all that was needed from his usual supplier. He uses an old transmission casing for his mailbox!
Who is best to call re Pinion Bearing parts and such? I'm in NC but anywhere would be good. The car is on the rack right now so you can call me at 828 779-9028 in the interest of haste.... Thanks! JR
Needing help with battery hookup.
Thanks for all the help. I've got it right now. ( I had the headlights on but didn't notice because it was such a bright day.)
