jcaswell
  1. I have a 1995 Caterham with 2 lt zetec can I source a water pump for the motor on this side of the pond. My motor is early 90's NGA motor. Any help would be appreciated.
  2. What model of car do you have, is it a Ford Zetec 2 Ltr? My car has vintage gauges fro approximately 1995.
  3. Can some give me some input on what would be the proper thermostat temperature wise to use in my Zetec the motor is 95 to 98 Ford. Also can any one give me any input on the water temp sender replacement and I have vdo gauges. The thermostat housing is plastic and my temp sender screws in below the thermostat and has a single wire sender with a ground wire on the body of the sender with a washer under the threaded body of sender where you thread it into thermostat housing.
  4. I found a BMW motorcyle battery that fit 98%. Just had to rebend the one side of the battery box by about 3mm and it fits great and has plenty of power to turn over.
  5. My battery is toast the battery box on the right side fire wall area is 4 3/4" W, 7" L, the height of the battery is 6 1/2" H can anyone give me a hint where to source a battery that could fit without making a new battery box or holder.
  6. Just got my Seven with zetec on throttle bodies, plain back end no spare tire. Mounted back plate right on aluminum with wide velcro and it works great. I need to have some ideas on how to do the front plate as I am Canadian we must have front and back plates. All comments welcome. Cheers Jamie.
