Hello, I have a 2011 R500 (owner for ~4 years) with zero compression in cylinder 4, from a broken valve spring. I understand this is not uncommon from the various threads, and was planning to remove the head (in car) and start the process of inspection and repair (obviously including all new springs).
However, I’m concerned that the instructions I’ve seen reference the tooling bar (and crank pin) to align/time the cam shafts, but my cams have vernier cam chain sprockets, and hence it appears the tooling bar would not fit, due to slightly different angles. Is the vernier installation intended to adjust the timing relative to the crank, or between the two cam shafts (or both) - beginner question, sorry!
Now I’m not sure if I should attempt the head removal (and loss of settings), or if I’m better to take the engine out (looks tight/tricky?) and send to an expert; perhaps the guys in CO.
Feedback gratefully received; perhaps the verniers are standard for the R500 and I’m over thinking it?
I’m based in Charlotte NC, so any local experts, or other recommendation/guidance would be ace.
Thank you!
