Addlightness93
    New York, NY
    None
  1. Fan, motor, and shroud. All in excellent shape. $200 obo plus shipping
  2. Lucas Electronic ignition amplifier. $125 OBO
  3. Very helpful advice, I’ll do that. Thank you!
  4. Checked but a little rudimentary. Could definitely do a better job. Or potentially just replace the floats (maybe brass?).
  5. Hello! Looking for some guidance. Have a Super sprint with a 1700 cross flow and twin DCOE 40’s. When I turn sharply to the right I get a whiff of raw fuel, very strong. Doesn’t happen when turning to the left. It also happens if I jack the car up quite high on the right side. I replaced the carb gaskets (rubber) hoping it would help, and adjusted the float levels (as best I could, first time). Wondering if one of the floats is getting stuck because of the G forces. For reference I have plastic floats. Thank you for any and all insights!
  6. I ended up going with a replacement A frame from redline components
  7. That’s very helpful, thank you! And agreed I want something a little beefier. Would much prefer something like this doesn’t happen again!
  8. It ripped itself off the differential mount. I’m sure it can be fixed would just rather replace it
  9. Hello! wondering if anyone knows of a company that makes a replacement rear A frame as mine needs replacement. Or if maybe I have to have one made/mine repaired. Thank you!
  10. Where are you located?
