HUTCH
    Connecticut
    Caterham
  1. actually located the ecu sensor box...not where I was looking for but it''s there. Tried the disconnect the batery turn the key stuff without results. How else can you get the sensor to operate properly? makes sense to cover any easy stuff before blaming it on the ecu itself.
  2. can you please be more explicit on what this picture is showing
  3. the unit was sent out to guys that repair them and was returned as they had nothing like it and they were the ones that said it did not have the pats system car was built around 2002 as you can see we have an analogue key
  4. the unit was sent out to guys that repair them and was returned as they had nothing like it and they were the ones that said it did not have the pats system car was built around 2002 We sent it to them They inspected and this the result. EASY
  5. the unit was sent out to guys that repair them and was returned as they had nothing like it and they were the ones that said it did not have the pats system car was built around 2002
  6. can you answer the question about the ECU's available having the PATS system and whether it is compatible with my car which does not have it.> I have consulted numerous qualified people about this and have not found the answer so far. Best info is that they are not compatible which is a problem in that that is all that we can find,
  7. what is the ?scuttle" and what is RMSCI? If I found all this stuff the fact would be that the unit does not work as is. all the replacements have pats what would be the story with the dtuff like the black box? TRIED THE KEY AND BATTERY IDEA NO GO THE IGNITION SWITCH IS NOT ELECTRONIC NO PATS SYSTEM STILL NEED IDEAS
  8. I bought the car from Chis but he dissappeared. I will contact him to see what he has to offer!!!!!!!!!
  9. what is the ?scuttle" and what is RMSCI? If I found all this stuff the fact would be that the unit does not work as is. all the replacements have pats what would be the story with the dtuff like thoe black box? That's what I thought, New battery, same result. got any idea for tuners somewhat near Conn.?
  10. what is the ?scuttle" and what is RMSCI? If I found all this stuff the fact would be that the unit does not work as is. all the replacements have pats what would be the story with the dtuff like the black box? I dot have the blue box
  11. what is the ?scuttle" and what is RMSCI? If I found all this stuff the fact would be that the unit does not work as is. all the replacements have pats what would be the story with the dtuff like the black box?
  12. the hidden key theory sounds unlikely to me. That would not answer the question of why it all of a sudden stopped working when it was still in my garage
