captain pabst
captain pabst started following Maryland Inspection woes , CATERHAM RACE REAR CALIPER KIT 2 POT , Anyone Import a car through Baltimore in the past few weeks? and 1 other
captain pabst replied to ratchet's topic in Parts For Sale / Wanted
Are these still available? -
I was getting a bit with the fronts but as I picked up pace I was instructed to drop in from the corner
Just posting up here that I'll be attending the Colonial Cup Challenge Track day 8/28/2025 with my 420r. It would be great if some other Caterham's could make it out. I'll be in intermediate. https://kerbz.app/event/ccc-track-day-8-28-20205-1746847043
I made it to my first track day with the Caterham the other week. Shenandoah at Summit Point It was very rewarding. I was within a second of my Porsche GT4 on the same track. My top speed was at least 10 miles an hour slower on the main straight. so pretty interesting. I had no issues with Motion sickness which is my main hold up. My next track day will be 8/28/2025 at Summit Point Main for the Colonial Challenge Cup. Would be great if some other Caterhams could make it! https://kerbz.app/event/ccc-track-day-8-28-20205-1746847043
for the rears you can always put tires on the fronts (easier when the car is done) and jack the rear up until the calipers are more close to level / bleeder being the high poitn ( i did this as my car was "done" but was looking for a bit better bleed on the brakes)
So some research on the front adapters (with the 4 pot calipers in the front) say they need to be annealed if leaking (this is obviously really messy now that there is fluid in the system) another thing to try is to tighten loosen and tighten a few times making it seat better. Yes this actually worked for me, but i wished i had annealed mine before putting them in place Have you bled both valves on the front brakes? there is an inside and an outside for each caliper. my drivers front had a lot of air on the inside bleeder. I used a power bleeder and the old school way second and felt the brakes were done after pumping and cracking bleeders. Good luck! hope you finish up soon.
Will catch up to you next time.
Demoray where in MD are you?
I'm on R888R's so not welcome
Date Saved, thanks
Welp. Its all done... I have about 180 miles on it so far. It's a blast. I'll be taking it to a Porsche Club Autocross this weekend.
The red cage needed to be removed. Then I had a very thin Tweezer for vinyl that I was able to disengage the clip, then pushed it out from the front using a piece of Tig filler wire. Put it all back together and it started right up.
Anyone Know about de-pining the Body side of the Engine harness? I've got a no start and it appears the culprit is in this connecter. Pin numbers are for reference and probably not the actual connector because I'm not sure of the numbering on this connector. But It goes Red-5 White-6 black-7 on the engine side and then on the body harness it goes to White-5 Red-6 Black-7 (Red and White have switched positions). Leading to Crank Signal being at ECU pin 7 instead of 12 (which is supposed to be a power ground), and Crank Return is at Pin 11 (correct) and Power Ground is at pin 11 instead of 7.
Indeed, I have driven all of the tracks at Summit, but not every layout. Only been on track there with a Porsche GT4.
