Rashid_seyadi
Bahrain
Occupation
Aluminium sales
Se7en
Westfield and Ultralight
Thanks @nc7s4 for the shocks ill send them an email when i get to that step. busy day today got the fluids out the radiator fluid was horrible. removed the Engine and gearbox out but ill need your help here am i missing something here the gearbox and engine are stuck together removed all the bolts. Total 9 bolts. I can get them apart by about an inch or so but not in full is there something wrong π€ Got the engine and gearbox on the ground safely and tried everything to get them apart but i couldnt π₯²
Hi all, i have started a new thread in the build forum to continue the rebuild. New pics have been added hopefully they show everything requested above. Your assistance is appreciatedπππ
Rashid_seyadi started following New ultralight owner and WCM Ultralight rebuild
Hi, today i got delivery to the only Ultralight in Bahrain which was stored for more than 10 years. Thankfully the car runs very well didnt get to drive it just got the engine running and it sounds well thankfully. Ill be starting from the front of rhe car ill be removing the engine changing most of the gaskets and seals with the trans gaskets. All the fluids of the car, tidying things up behind the dash and the engine loom. Inspecting the fuel tank and lines. Moving on to the brake system which seems to be very bad in terms of condition with the shocks which are leaking in all four tyres. The rear right hub seems to have a damaged bearing. Or maybe the calliper is stuck. Would like to get your thoughts on how would you see the start should be and what should be looking for first. Any ideas recommendations that would be highly appreciated. Hope you enjoy the rebuild.
Thanks alot for the welcoming π The car is yet to be delivered should be at home by Tuesday/Wednesday. Those pictures where taken in the warehouse. i do have few info about the car the engine is a f22c with its gearbox unmodified the diff is from a subara sti with lsd and uprated driveshaft hand brake is hydraulic and electronic steering wheel rest should be as is from WCM i did see that the master cylinders are willwood and the brake system is also willwood wheel size is 15inch the car runs fine drove it around the warehouse. Ill take more pics for the specific things mentioned and more. thanks alot for the help honestly this forum is amazing im also a member in westfield's forum and honestly i had to learn it the hard way with my westfield didnt expect such welcoming from all. Ill post the pictures once i get the car should be clearer. thanks alot πππ
Thank you for the warm welcoming. Actually kit cars in general are really rare in Bahrain so far we have 5 cars only mixed between caterhams, westfields and an Ultralite as they are illegal to be driven on roads. Therefore paying this much for a car to drive for few months in winter on track since its extremely hot out here is pretty much unworthy. Story starts when the car wasnt brought to the country in 2011 from UAE and the owner used it specifically for autocross for like 2 years and was the winner of the championship. Then stored in a closed warehouse from 2013 till last week where he decided to sell all his cars and leave the country. Being one of the owners of the few kit cars in Bahrain luckily he came first to me and i couldnt resist buying it. (Kit cars addict). The car wasnt in good shape at all it needs alot of love shouldnt be a problem i guess. leaks all over the place from every single item that has oil. Surprisingly rust is considerably fine considering its age. The westfield had approximately the same story which turned out really well id say. ill keep you guys posted. With the updates or shall i start a new build thread?
Hi, i currently own this a FW Westfield with a fully built duratec engine and have just recently bought an Ultralight. Having no experience with the Ultralights and being a one of a kind in the country id say the forum has memebers that have experts in such cars. The car has been stored for more than 10 years. Is there something that i have to keep in mind or maybe consider servicing other than the usual oils, etc or upgrading stuff in the chassis that were discovered to be as weak spots over time.
