Sjwarden
Ohio
Se7en
Caterham Super Seven
Importing Caterham Engine From England
Sjwarden replied to Sjwarden's topic in General Sevens Discussion
I did just get the engine a few days ago. Engine was shipped via FedEx deferred air, and the shipping was actually reasonable, about $500-600 dollars insured. I hired a broker just in case but FedEx actually handled everything, my broker really never had to get involved. Engine cleared customs no issues at all and no forms from me required. I was surprised by this, and how easy it actually ended up being. Crate with engine and parts came in through the Memphis hub, took one day to clear customs and another two days to make it to me in Ohio. I am sure I will get a duty and tax bill from FedEx any day, but I already figured that into the costs and I am not worried as the current tariff with England is about 10% on car parts/engines that are being used in a UK made vehicle. Spent all day today getting started on removing the engine from the Caterham and preparing the new engine to go in. New engine is identical to my broken one, and this is my third time taking the engine in and out, so I am getting pretty quick at this. Will probably have the old engine out tomorrow, and begin transferring some of the items I need from it to the new engine. Hopefully will have the new engine installed and broken in by March. Fingers crossed it works as intended. Total costs so far, pending that tariffs and duties bill from FedEx, is about $7 grand, so with taxes and duties it will end up close to $8,000. However that cost includes the engine, crating, shipping and several other parts including a lightweight flywheel and new throttle body. Not cheap, but not catastrophic, and for a nice rebuilt engine from DVA I think worth it. -
Thank you Scott. Ya I found that note as well as several other publications on EPA's site. Sort of clear as mud as to which exemption applies and what to put on the forms though. I think this will end up being the exemption on the EPA form for non-chassis mounted engines, which would be code W on the 3520-1 form. This car and engine are exempt from any EPA certification, and so I think the non-chassis mounted import code applies best. I am not sure though and would like to hear if anyone else has imported an engine not mounted in a car, and what code they used or if they had any trouble. Problem with my current 1.8 K VVC is that it has a bad oil leak under power and I believe there is a crack in the block which I haven't been able to isolate precisely yet. After two times R&I the engine and transmission to fix/diagnose, and given the time needed to disassemble my engine and diagnose further, seemed to make sense to source a used replacement. Undriveable with the current leak. -
Hoping someone here has some experience in this area and can share it. I have a 1999 Super Seven with a 1.8 Rover K VVC engine that is broken and needs replaced. Connected with Dave at DVA in England for a replacement engine, and he found one of the same year to ship me. My concern is over the importing of the engine. The EPA forms and policies are confusing. The engine and car are both over 21 years old and therefore exempted/excluded. However the forms don’t seem to have a good fit for importing a loose non chassis mounted engine for use in my Caterham. Not really worried about duties and tariffs, just don’t want to run afoul of any import rules with the EPA. Anyone have any experience with this that can share how it worked and have any tips? Any help appreciated, thank you. Sam
Caterham 1.8 K Series Rear Main Seal Replacement
Sjwarden replied to Sjwarden's topic in General Tech
Thank you, big help. Will reuse the clutch disc then, seems in good shape. -
Engine is out. Rear crank seal is leaking oil, so that is confirmed. It looks fine but it is definitely leaking. Checking clutch. What do you all think, worth replacing disc or should this last a lot longer? I was thinking of just replacing while I am in here, but I am having trouble finding the part for the clutch disc. It is an AP racing part, I believe 7.5 inch, 23 spline. Anyone have a good part number for this? Any thoughts or concerns on review of the pics please chime in, any help appreciated. I am fabbing up a clamp for the new rear seal now and should have this pulled and replaced by tomorrow. -
LOL, that would make it easier. -
Thank you for that... I'll plan accordingly. -
I have a leaking rear main seal on my 1.8k VVC Caterham. Got the correct part and will be trying to replace this on my own. Is it possible to do this job without removing the engine? Can I just drop the transmission, remove the clutch and flywheel and replace from there? Chassis is a 1999 S3 Super Seven. Any advice appreciated.
What Diff Oil To Use?? 1999 Caterham Super Seven
I made a video that might help. With wheels turning you can see the diff turn. e7d68373bbfc918c574327ab0b40bb36.MP4 -
Ok, reviving this thread a bit. Thank you for all the help so far. In an effort to nail this down so I don't accidentally put the wrong oil in and ruin this diff I got some more info. I took the suggestion above and purchased a camera probe with light. Got the attached pics of the external diff housing and some of the inside. This inside pics are terrible so not sure anything can be made of them. Outside appears to be Ford Sierra diff as mentioned. Also, if this helps, when jacked up and rotating one rear wheel, the other wheel also turns in the same direction. Diff oil appeared nice and amber and clean, but I assume that is because the car hasn't been driven in about 2-3weeks. Diff drain/fill plug was a 10mm Allen and it was magnetic. There was a few black metal filings attached on the inside magnet that I cleaned off. I might try and get a few more pics of the inside and push the camera deep into the oil, but I thought this might be enough for a firm opinion on diff type. -
Thank you all for the suggestions and advice. I did go ahead and buy a boroscope, should come in handy. I did also check the rover assembly manuals and they refer to the owners manuals for the oil specs. I found an owners manual that seems close in year to mine and I think in combination with a boroscope to verify the diff type I can nail this down. Also might send away for an oil analysis as coffee break suggested. -
Been lurking on this site and dreaming of a Caterham for years. Finally got one a week ago. Planning on doing some maintenance and checks over the winter, and preparing for a lot of miles come better weather. My new car is a kit that was assembled here in the States in 1999, a super seven K series car with the 1.8 VVC engine and Caterham’s 6 speed gearbox from that time. It is also fitted with an LSD. I have a VIN SDKLDKANSX0010168. Wondering what gear oil I should use to top off the diff in this vehicle but I cannot figure out what type of LSD it has. Does anyone have any ideas? Unfortunately the VIN plate has no info other than the VIN number on it. Thank you for any help or input.
