miles50
    Platte City, Mo
  1. You can remove the pump, on the face of the pump you can see the oil pressure relief spring and retainer. You can take a punch or socket the size of the retainer and punch it in around a 1/32 or 1/16 put a washer between the retainer and block to keep it in place on reassembly and see what increase you get. Unfortunately the oil pressure relief valve is unservicable otherwise. More pressure punch in a little farther. Good luck
