I just noticed I'm missing both bolts that hold the standard roll bar hoop to the mounts behind the seats.
I'm looking to buy replacement bolts, spring washers, and flat washers.
I want to make sure I understand correctly, with 4pt harness, I should get 7/16" UNF x 1" screws, NOT the 5/16" UNF x 1" screws that would be used if I had standard seat belts.
The Assembly Guide says the following, which, is confusing. (note: I have 4 pt harnesses installed)
"6.11 Standard Roll bar
This is best fitted after any work required in the boot and before fitment of the boot cover.
The roll bar attaches on top of the seat bulkhead and inside the rear of the boot.
a) 5/16”UNF x 1” set screws and spring washers are used into the seat bulkhead,
tighten to 20-25 lbft. The rear legs locate into the chassis brackets in the boot and are
secured using 5/16”UNF x 2” bolts, washers either side and nylocs, again tighten to 20-
251bft.
b) Fastening of the forward ends is dependent on the type of seat belts being fitted.
Static three point lap and diagonal belt:
The rollbar is secured using the same bolt as used by the top seat belt mount. The roilbar
is fitted underneath one of the thinner seatbelt spacer bushes. The seatbelt bolts are
tightened to 40-45 lbft.
Static four point harness:
The rolibar is secured at the front by 7/16” UNF x 1” set screws and spring washers.
Tighten to 20-25 lbft."
Thanks!
