Gabriel Tyler
Everything posted by Gabriel Tyler
  1. Working heater core assembly from a 2003 SV. What you see is what you get. $120 shipped to anywhere in the lower 48 states.
      • 1
      • Like
  2. Sorry to take so long getting back to you. Yes, I'd take $50 for each of the small gauges.
  3. Worked fine when removed from car. Going to a Stack setup. The car was using a 2.3L Ford Duratec, but not 100% sure what motor these gauges were meant to interface with. See part numbers. $200 shipped for the lot to anywhere in the USA.
  4. The SV seats and the narrow seats are in fact different. These blackbird seat part numbers show as the correct seats for a narrow chassis (they will fit in a wide chassis as well, however). It is likely the seats were added to the SV by Magnus after he originally built the car.
  5. Slonie, The part number is 73467 which from my knowledge was originally a narrow chassis seat. These were in the car that I purchased from Magnus Feuer. He likely added the seat in after his orginal build.
  6. SOLD! Used seats from my 2003 SV. Decal on the side lists them as Caterham Blackbird seats. Decent condition for the age. Stupid light weight. Seats only. No sliders or rails. $1000 OBO for the pair. Located in Shingke Springs CA. May be able to ship depending on location. SOLD!
  7. He built a really solid car, but it was wired up with his own design Magden display and when that went out it was pretty much impossible to get it working again. The car was a little rough around the edges from plenty of track use, so I tore it down to the bare frame and am rebuilding it as we speak.
  8. These came off a 2003 SAE spec SV car that I purchased from Magnus Feuer (he was fairly active on here years ago). This particular car was converted to a 2.3L 250HP Cosworth build. Dedion rear layout. Suspension worked great when I pulled them off about 5 years since then. Springs have chipped paint and could use fresh coat. $200 shipped to anywhere in the USA.
