Torqueman
1 Follower
  1. Seven cars with turbo are quick
  2. Hi there Noshest! Great looking car I have a friend that has recently finished his FW Westfield (same color) but with Saab turbo engine as my self. Where about in Stockholm are you? I´m in Nykvarn and there are two more Westfield turboed cars in Solna and Haninge. Maybe we can arange a garage meeting ore a blat when spring arrives! So long!
  3. Wow, jetfighter grey Looks good Aris!
  4. http://www.carwp.com.br/2013/05/2013-indy-seven-roadster-concept-by.html
  5. Thanks Aris! I have sent RWD a mail:)
  6. Aris, wich bellhousing are u using, RVD motorsports?
  7. Yepp, was thinking if there is some hydralics that fits inside the bellhousing. Otherwise its all back to the drawing bord and make a new adapter for the cluch cylinder.
  8. Aris, I´m guessing that you use hydrlic cluch on T5. What do u have?
  9. Hopfully I have to make a new propshaft, modify the old belhousing so it fits the T5 and make a gearstick extension... And a new cluch plate... puhh... And hopfully the EFR will be fitted! Cant you register the car for the street if you want?
  10. Santa is a little bit early... I went for the wide gearkit wich have more rev drop between gears, and 0,8 fift wich is fine when crusing.
  11. A friend of mine did find this: http://www.qstarz.com/ Its cheaper than the Racelogic but if it is as good as the V-box I dont know. It looks neater thougt. By the way, I have a T5 gearbox with gerboxman gearkit (quaife?) on its way. Hopfully the better gear ratios will make the car perform better. Cheers
