Hello,
Yes Skip, thats my car on the dyno. By the way, I have your sub-frame brace installed on my 2000 Miata. That car is set up with a BEGi Series II+ turbo, factory sport suspension & LSD, FM butterfly brace, single turbo exhaust and free flow cat, AEM air fuel meter, AEM alcohol injection, HardDog roll bar, GoodWin rotors, and Hawk HP pads. The BEGi fuel system allows me to make power and never worry about the CEL.
All in all, its a very well ballanced car. Good enough that I don't miss the Elise when I'm driving it.
Ok, about the SVT...
Power curves, yes, there is a dip, a bit below 3000 RPM. Not as bad as it was with the stock tune. That dip is present on factory stock Focus SVT's. My exhaust system is unlike the SVT Focus, so I do not beleive that is the root cause.
As for the oil cooler, Ford's SVT team installed the oil cooler for good reasons. Many Focus SVT drivers add an external oil cooler as well, as do some Caterham drivers with the 2.0 Zetec. Given that the SVT motor has a higher red-line, some form of oil cooling is a good thing. Also Ford uses a better oil filter, again, cheap insurance.
In the Caterham, neither of these will clear the passanger side motor mount, and that is the only reason they are removed. I'm more thinking of being stuck in traffic than I am thinking about the track. So adding the oil cooler and remote filter brings the engine back to something closer to what the SVT team designed it to be, with the right oil filter.
As far as the ECU work...
This is still a work in progress. Once complete, Sevens & Elans will be able to offer an 'upgrade' to make the cars pass OBD2 inspection.
There are at least two ways to acheive this. One 'sorta' works, and is fairly easy. The other is a little more work, but might be the 'right' way to go in the long run.
Its also possible to do this with the Duratec, but it would envolve tossing the Caterham ECU and wiring harness. But you would have a 'legal' car.
