LotusGuy48
    Orlando, FL.
  • Interests
    Golf, cycling, travel and cars.
  • Occupation
    Aerospace sales engineer.
  1. I have a 2001 Zetec powered Superformance S1 Lotus 7 replica if you're interested located in Orlando FL. Let me know if you have any interest and I can send you more information and pictures.
  2. Just heard back from Steve on his S1 Honda S2000 engine project. Apparently the Honda S2000 engine was an F20C. My memory says the early models up through 2003 were 293 hp and redlined at 9,000 rpm. Later models were detuned to 284 hp and redlined at 8,500 rpm. With headers the early models gained to 300 hp. His was a low milage early model. Those were more in demand & usually went for $5,000 to $6,000 with transmission, ECM & wiring harness. He watched eBay for 3 months & picked his up for $3,000. Then installation including a new custom drive shaft was another $2,500 to $3,000 along with custom headers as the exhaust is on the passenger side as I mentioned. So you would be looking at around $6K for this sort of project or an out the door price of around $25K.
  3. I believe the cost of the Honda S2000 engine was around $3,000, Steve bought it from a shop in Jacksonville Florida that sells parts from wrecks and had it installed by another shop. Let me contact him and get some actual numbers for you. Be back shortly.
  4. A very good friend of mine here in Florida bought an S1 and put a Honda S2000 engine in it. With some minor mods he got around 275 bhp out of it. Only problem was that the exhaust manifold was on the passenger side so he had to cut a hole on that side of the engine bay.
  5. For sale, a 2001 Superformance S1 Lotus 7 replica with 13K miles. Price is reduced to $18,995. This car was manufactured in South Africa by the same company that makes the AC Cobra and Ford GT40 replicas along with the Noble. Considered by many to be the very best Lotus 7 replica ever made, it comes with a tube frame making the car very light (around 1,400 lbs). Factory performance figures are 0-60 in 5.3 seconds with a top speed of 125 mph. Fuel economy is around 30 mpg overall from a 10.6 gallon tank. The body work is very high quality fiberglass and aluminum with very tight seams better than one sees on many production cars. The front suspension has double wishbone control arms with castor and kingpin angle adjustment and billet machined aluminum-alloy uprights with independent camber adjustment with adjustable coil-over damper units. The rear suspension has a live axle located with four trailing arms and state-of-the-art Mumford linkage giving optimum roll center control. The compact suspension package much improves rear trunk space with enhanced handling, performance and ride comfort. The car also has a decent size trunk about the same size as a Mazda MX-5. There is a lockable glove box and fresh air ventilation with two speed fan assist. The car has windows that slide up and down as well as a top (not shown) that can be used as a "T" top or stored in a bag in the trunk. The doors can be easily removed for that motorcycle feeling. The exhaust sound is nice and throaty without being too loud. The cockpit features a carbon fiber dashboard with full VDO instrumentation with an oil pressure gauge and tachometer in front of the driver with a center mounted speedometer and smaller gauges for oil and coolant temperatures, a fuel gauge and an analog clock. Synthetic Mobil 1 oil has always been used from day one and the car comes with an Aces sequential shift light system located on top of the dash to show optimum power and shift points. The engine is a Ford Zetec 2 litre 16 valve dual overhead cam engine with Superformance headers putting out around 175 hp mated to a 5-speed very smooth and fast shifting short throw transmission very similar to the MX-5 with a very progressive clutch. The front brakes are ventilated discs with lightweight Wilwood 4-pot calipers; the rear brakes are solid discs with Wilwood 4-pot calipers with a Wilwood spot caliper hand brake. The seats do not move in the S1, the pedals are on a carriage that moves with a turn of a large aluminum knob under the dash. Pedal set-up is perfect for heel and toe driving. The steering geometry is designed to minimize bump steer while giving sufficient angle compensation in tight turns. With three turns lock to lock the S1 has a 27 ft turning radius. Full harness seat belts are standard equipment. The car is mechanically perfect although it does have a couple of minor paint blemishes This car is for you if you want super car performance at a reasonable price with looks that generate admiring attention and lots of thumbs up (even from state troopers) and if you stop for gas be prepared to stay at least 15 minutes or so to answer all the inevitable questions that will come your way. Only reason for sale is I am buying an Elise. For more information call David at 407.256.1028 or email LotusGuy48@earthlink.net. The car is located in Apopka just outside Orlando FL.
  6. For sale, a 2001 Superformance S1 Lotus 7 replica with 13K miles. I thought I had this sold but am reposting due to time wasters and people who don't put their money where their mouth is. The car is registered in Florida as a 1969 Lotus and has a clear title. Price is $19,995. This car was manufactured in South Africa by the same company that makes the AC Cobra and Ford GT40 replicas along with the Noble. Considered by many to be the very best Lotus 7 replica ever made, it comes with a tube frame making the car very light (around 1,400 lbs). Factory performance figures are 0-60 in 5.3 seconds with a top speed of 125 mph. Fuel economy is around 30 mpg overall from a 10.6 gallon tank. The body work is very high quality fiberglass and aluminum with very tight seams better than one sees on many production cars. The front suspension has double wishbone control arms with castor and kingpin angle adjustment and billet machined aluminum-alloy uprights with independent camber adjustment with adjustable coil-over damper units. The rear suspension has a live axle located with four trailing arms and state-of-the-art Mumford linkage giving optimum roll center control. The compact suspension package much improves rear trunk space with enhanced handling, performance and ride comfort. The car also has a decent size trunk about the same size as a Mazda MX-5. There is a lockable glove box and fresh air ventilation with two speed fan assist. The car has windows that slide up and down as well as a top (not shown) that can be used as a "T" top or stored in a bag in the trunk. The doors can be easily removed for that motorcycle feeling. The exhaust sound is nice and throaty without being too loud. The cockpit features a carbon fiber dashboard with full VDO instrumentation with an oil pressure gauge and tachometer in front of the driver with a center mounted speedometer and smaller gauges for oil and coolant temperatures, a fuel gauge and an analog clock. Synthetic Mobil 1 oil has always been used from day one and the car comes with an Aces sequential shift light system located on top of the dash to show optimum power and shift points. The engine is a Ford Zetec 2 litre 16 valve dual overhead cam engine with Superformance headers putting out around 175 hp mated to a 5-speed very smooth and fast shifting short throw transmission very similar to the MX-5 with a very progressive clutch. The front brakes are ventilated discs with lightweight Wilwood 4-pot calipers; the rear brakes are solid discs with Wilwood 4-pot calipers with a Wilwood spot caliper hand brake. The seats do not move in the S1, the pedals are on a carriage that moves with a turn of a large aluminum knob under the dash. Pedal set-up is perfect for heel and toe driving. The steering geometry is designed to minimize bump steer while giving sufficient angle compensation in tight turns. With three turns lock to lock the S1 has a 27 ft turning radius. Full harness seat belts are standard equipment. The car is mechanically perfect although it does have a couple of minor paint blemishes This car is for you if you want super car performance at a reasonable price with looks that generate admiring attention and lots of thumbs up (even from state troopers) and if you stop for gas be prepared to stay at least 15 minutes or so to answer all the inevitable questions that will come your way. Only reason for sale is I am buying an Elise. For more information call David at 407.256.1028 or email LotusGuy48@earthlink.net. The car is located in Apopka just outside Orlando FL. http://images.craigslist.org/3nc3m53p15Z45Q25P4ac5aa826c2ba6921831.jpghttp://images.craigslist.org/3kc3m93pd5V45Z65R2acte0b3113065371748.jpghttp://images.craigslist.org/3n53mf3o25Y45T35P2ac539963963ebc91044.jpghttp://images.craigslist.org/3p13o73lf5O65V25X6act377353d5abb31d49.jpg
  7. OK will do.
  8. For sale, a 2001 Superformance S1 Lotus 7 replica with 13K miles. Re-posted at a reduced price of $19,995 firm. The car is registered in Florida as a 1969 Lotus and has a clear title. This car was manufactured in South Africa by the same company that makes the AC Cobra and Ford GT40 replicas along with the Noble. Considered by many to be the very best Lotus 7 replica ever made, it comes with a tube frame making the car very light (around 1,400 lbs). Factory performance figures are 0-60 in 5.3 seconds with a top speed of 125 mph. Fuel economy is around 30 mpg overall from a 10.6 gallon tank. The body work is very high quality fiberglass and aluminum with very tight seams better than one sees on many production cars. The front suspension has double wishbone control arms with castor and kingpin angle adjustment and billet machined aluminum-alloy uprights with independent camber adjustment with adjustable coil-over damper units. The rear suspension has a live axle located with four trailing arms and state-of-the-art Mumford linkage giving optimum roll center control. The compact suspension package much improves rear trunk space with enhanced handling, performance and ride comfort. The car also has a decent size trunk about the same size as a Mazda MX-5. There is a lockable glove box and fresh air ventilation with two speed fan assist. The car has windows that slide up and down as well as a top (not shown) that can be used as a "T" top or stored in a bag in the trunk. The doors can be easily removed for that motorcycle feeling. The exhaust sound is nice and throaty without being too loud. The cockpit features a carbon fiber dashboard with full VDO instrumentation with an oil pressure gauge and tachometer in front of the driver with a center mounted speedometer and smaller gauges for oil and coolant temperatures, a fuel gauge and an analog clock. Synthetic Mobil 1 oil has always been used from day one and the car comes with an Aces sequential shift light system located on top of the dash to show optimum power and shift points. The engine is a Ford Zetec 2 litre 16 valve dual overhead cam engine with Superformance headers putting out around 175 hp mated to a 5-speed very smooth and fast shifting short throw transmission very similar to the MX-5 with a very progressive clutch. The front brakes are ventilated discs with lightweight Wilwood 4-pot calipers; the rear brakes are solid discs with Wilwood 4-pot calipers with a Wilwood spot caliper hand brake. The seats do not move in the S1, the pedals are on a carriage that moves with a turn of a large aluminum knob under the dash. Pedal set-up is perfect for heel and toe driving. The steering geometry is designed to minimize bump steer while giving sufficient angle compensation in tight turns. With three turns lock to lock the S1 has a 27 ft turning radius. Full harness seat belts are standard equipment. The car is mechanically perfect although it does have a couple of minor paint blemishes This car is for you if you want super car performance at a reasonable price with looks that generate admiring attention and lots of thumbs up (even from state troopers) and if you stop for gas be prepared to stay at least 15 minutes or so to answer all the inevitable questions that will come your way. Only reason for sale is I am buying an Elise. For more information call David at 407.256.1028 or email LotusGuy48@earthlink.net. The car is located in Apopka just outside Orlando FL. http://images.craigslist.org/3nc3m53p15Z45Q25P4ac5aa826c2ba6921831.jpghttp://images.craigslist.org/3kc3m93pd5V45Z65R2acte0b3113065371748.jpghttp://images.craigslist.org/3n53mf3o25Y45T35P2ac539963963ebc91044.jpghttp://images.craigslist.org/3p13o73lf5O65V25X6act377353d5abb31d49.jpg
  9. For sale, a 2001 Superformance S1 Lotus 7 replica with 13K miles. Price just reduced. This car was manufactured in South Africa by the same company that makes the AC Cobra and Ford GT40 replicas along with the Noble. Considered by many to be the very best Lotus 7 replica ever made, it comes with a tube frame making the car very light (around 1,400 lbs). Factory performance figures are 0-60 in 5.3 seconds with a top speed of 125 mph. Fuel economy is around 30 mpg overall. The body work is very high quality fiberglass and aluminum with very tight seams better than one sees on many production cars. The suspension is very well engineered with more ways to adjust the front end than anything short of a pure open-wheeled race car. The rear suspension is a solid rear axle that is located by a sophisticated Mumford linkage system that keeps the weight very low in the car. The car also has a decent size trunk about the same size as a Mazda MX-5. There is a lockable glove box and fresh air ventilation with two speed fan assist. The car has windows that slide up and down as well as a top (not shown) that can be used as a "T" top or stored in a bag in the trunk. The doors can be easily removed for that motorcycle feeling. The exhaust sound is nice and throaty without being over the top. The cockpit features a carbon fiber dashboard with full instrumentation - an oil pressure gauge and tachometer in front of the driver with center mounted speedometer and smaller gauges for oil and coolant temperatures, a fuel gauge and an analog clock. Synthetic Mobil 1 oil has always been used from day one and the car comes with an Aces sequential shift light system located on top of the dash to show optimum power and shift points. The engine is a Ford Z-Tec 2 litre 16 valve dual overhead cam engine with Superformance headers putting out around 175 hp mated to a 5-speed very smooth and fast shifting short throw transmission very similar to the MX-5 with a very progressive clutch. Brakes are 4-piston Wilwood with dual master cylinders with brake bias adjustment. The seats do not move in the S1; the pedals are on a carriage that moves with a turn of a large aluminum knob under the dash. Pedal set-up is perfect for heel and toe driving. The steering geometry is designed to minimize bump steer while giving sufficient angle compensation in tight turns. With three turns lock to lock the S1 has a 27 ft turning radius. Full harness seat belts are standard equipment. The car is mechanically perfect although it does have a couple of minor paint blemishes This car is for you if you want super car performance at a reasonable price with looks that generate admiring attention and lots of thumbs up (even from state troopers) and if you stop for gas be prepared to stay at least 15 minutes or so to answer all the inevitable questions that will come your way. Only reason for sale is I am buying an Elise. For more information call David at 407.256.1028 or email LotusGuy48@earthlink.net. The car is located in Apopka just outside Orlando FL. http://images.craigslist.org/3nc3m53p15Z45Q25P4ac5aa826c2ba6921831.jpghttp://images.craigslist.org/3kc3m93pd5V45Z65R2acte0b3113065371748.jpghttp://images.craigslist.org/3n53mf3o25Y45T35P2ac539963963ebc91044.jpghttp://images.craigslist.org/3p13o73lf5O65V25X6act377353d5abb31d49.jpg
