Blindcars Posted October 22, 2014 Posted October 22, 2014 i have (10) 12x1.25 two and 1/4" wheel studs for the Wilwood hubs on a ultralight that i wont be using as i had to go to a 3" long stud dye to the use of spacers on the front. Free if anyone needs them.
Blindcars Posted October 22, 2014 Author Posted October 22, 2014 Forgot to add that thet are a 10.9 hardness
RGTorque Posted October 22, 2014 Posted October 22, 2014 where did you get the 3" longs? i could use some longer studs.
Blindcars Posted October 22, 2014 Author Posted October 22, 2014 Bel-Metric Fastners 1-800-544-1624 Here is the ussue: I searched high and low to find 3" studs in a 12x1.25 and 10.9 hardness. Nada, just not available unless you want to have it custom made at around $18.00 per stud. What i did find from Bel-metric was M12x1.25x100 full thread 10.9 hex head bolts. 100mm translates to 4" of full thread. I took the bolts when recived and had a friend who owns a fastber supply to cut the heads of at the length i needed (3"). Bel-Metric waa the only supplier i found that had a "full thread" bolt in 10.9 hardness above 2 1/2 inches. He said they had a 100 in stock and are rare to find so he typically buys the lot when he finds them. Not cheap, 10 bolts will run you $85.60 but its better than $16 to 20 per custom made stud Hope info helps
Blindcars Posted October 22, 2014 Author Posted October 22, 2014 Ugh.. Forgot to add.. The rear studs are easy to find in longer length. Ebay.. 20.00 for 10 studs withe the correct diameter knurled shoulder. The fronts are the tricky ones because they have to thread into the Wilwood hubs. Mine thread in 1" before they seat which leaves me 2" of stud sticking out for the rotor hat and wheel.
