Note: to Mod, if this is not the right place I can delete this ad. Thank you for letting me post.
1999 LOTUS ESPRIT V8 TWIN TURBO
THE ULTIMATE LOTUS ESPRIT UPGRADE !
Turn key -- nothing else to do. No mechanical issue. The car perform very strong & flawlessly.
Can be driven in any destination you want.
THE HISTORY:
I bought the car in Irvine California - I am the second owner. The car has 43,000 in the odometer from the previous owner.
It has a documented service log from Vikings Lotus motorsports (service log can be requested).The car now has 48,504 miles.
I was not able to drive the car much due to an eye injury. I only put 5,000 miles for the past 9 years owning it. I noticed that I constantly adding an anti freeze. I never suspected of anything wrong with the car at the time. In the later part, the car gave up and spewing white smokes. I called Viking motorsports and dug the service record. The previous owner never told me that he overheated the car, slowly contaminated the piston liners. The car was re-build Sept. 2011 at 46,800 miles.& finished 2012.
THE REBUILD:
The engine was professionally rebuilt by one of the NASCAR engine builder in the Northeast. The engine was "BLUE PRINTED" and the tolerance & torque were documented.
https://www.dropbox.com/s/f96fnv7qyxbg43p/EngineRebuild1.PDF?dl=0
The head was ported and blue printed. Utilized the flow of each port using flow bench for maximum power.
https://www.dropbox.com/s/x70hqduzqqthvct/EngineRebuild2.PDF?dl=0
The engine is newly broke in and I put 1,704 miles after the rebuild.
The GTO Engineering upgrade transmission and differential Quaife ATB was performed by a retired Tyrell formula 1 mechanic.
THE PARTS:
New 8 FORGED JE PISTONS.
New JE Piston rings
New head job (valve)
New turbo
New 8 Lotus cylinder head liners
Replaced all gaskets
New head gasket
New valve springs
New cylinder head valves (intake & exhaust)
3400 hylomar sealant
New ARP block/head bolts
New rod/journal bearings
New heavy duty "blue" timing belt
New timing belt tensioners
New (2) ignition coils
New sparkplug wire sets & plugs
New Idle valve
Replaced all fuel injection sensors
Brand new (8) injectors
New idle valve
New hoses & clamps
Replaced main seals & driveshaft seals
THE UPGRADES:
GTO ENGINEERING strong transmission upgrades (complete kits)
QUAIFE ATB differential
https://www.dropbox.com/s/2a2y72601xl2cyd/gtokit.jpg?dl=0
Two new upgrade Garrett turbo T28 upgrades
Johan ECU chip (similar to Lotus red race ecu)
AP Racing stage 3 clutch
JE forged pistons & rings
Eight Lotus Liners
Air to air intercooler (simple - less complex & less something go wrong - functional)
It has a custom stainless trunk – I can give you the original
HKS blowoff valves (2)
Four brand new goodyear EAGLE F1 ultra hi-performance tires
Four new Lotus hard to get OZ Nova wheels
3 rows radiator
Elise steering wheel conversion
Round tail lights conversion
LED Headlights - running light & fog light
Rear diffuser
Four brand new PROTECH adjustable springs & dampers (front 300lbs - rear 375lbs)
Dual center exhaust system with cheese grater
THE WHAT'S WRONG WITH THE CAR
The exhaust a bit louder than the stock lotus system.
There's a little scratch on the driver seat for going in and out...nothing major - no rip.
I noticed last July that the Air conditioning is not working - probably need to charge with R134A freon.
THE OWNER:
I owned 6 Lotuses through out the years, I know the ill wind of the Lotus especially the Esprit by heart. I do all my maintenance and service.
Although I never dyno the car, I can be best describe a ported head and the increase of boost will surely gets you at 450hp or over (RWHP)
I spent over 30 grand on the upgrades & rebuild.
I tried my best to be truthful & honest describing the car.
You can visit & test the car anytime - I live in the Northeast (Connecticut)
THE PRICE:
$46,000.00
You can Text me @ eight six zero - eight three seven - three six five four
I will entertain a REASONABLE OFFER but not the low baller.
THE CAR
http://tinypic.com/m/idyazn/3
http://tinypic.com/m/idyb21/3
http://tinypic.com/m/idyazt/3
http://tinypic.com/m/idyazq/3
http://tinypic.com/m/idyb0x/3
http://tinypic.com/m/idyazp/3
http://tinypic.com/m/id7jw4/3
http://tinypic.com/m/idyb20/3
http://tinypic.com/m/idyb1z/3
http://tinypic.com/m/idyb1k/3
http://tinypic.com/m/idyb0z/3
http://tinypic.com/m/idyb0y/3
http://tinypic.com/m/idyb0p/3
http://tinypic.com/m/idyb29/3
Edited by BusaNostra
